Datasheet HMC8402 (Analog Devices) - 5
Description2 GHz to 30 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page15 / 5 — Data Sheet. HMC8402. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter. Rating. …
RevisionE
File Format / SizePDF / 380 Kb
Data Sheet. HMC8402. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter. Rating. ESD CAUTION
Data Sheet HMC8402 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
Data Sheet HMC8402 ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Drain Bias Voltage (V stress rating only; functional operation of the product at these DD) 10 V or any other conditions above those indicated in the operational Gate Bias Voltage (VGG2) −2.6 V to +3.6 V section of this specification is not implied. Operation beyond RF Input Power (RFIN) 20 dBm the maximum operating conditions for extended periods may Channel Temperature 175°C affect product reliability. Continuous Power Dissipation (PDISS), 1.55 W TA = 85°C (Derate 17.2 mW/°C Above 85°C) Thermal Resistance, θJC (Channel to 58°C/W
ESD CAUTION
Bottom Die) Storage Temperature Range −65°C to +150°C Operating Temperature Range −55°C to +85°C ESD Sensitivity, Human Body Model (HBM) Class 1A (250 V) Rev. E | Page 5 of 15 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS 2 GHz TO 18 GHz FREQUENCY RANGE 18 GHz TO 26 GHz FREQUENCY RANGE 26 GHz TO 30 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BIASING PROCEDURES MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICs Handling Precautions Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
