Datasheet ADL5721 (Analog Devices)
Description5.9 GHz to 8.5 GHz, Low Noise Amplifier
Pages / Page15 / 1 — 5.9 GHz to 8.5 GHz, Low Noise Amplifier. Data Sheet. ADL5721. FEATURES. …
File Format / SizePDF / 389 Kb
5.9 GHz to 8.5 GHz, Low Noise Amplifier. Data Sheet. ADL5721. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADL5721 Analog Devices
5.9 GHz to 8.5 GHz, Low Noise Amplifier Data Sheet ADL5721 FEATURES FUNCTIONAL BLOCK DIAGRAM Frequency range: 5.9 GHz to 8.5 GHz ADL5721 Typical gain of 25 dB VCC1 VCC2 Low noise input 50Ω GND OUTN 100Ω Noise figure: <1.7 dB typical from 5.9 GHz to 8.5 GHz SINGLE-ENDED DIFFERENTIAL INPT OUTP High linearity input
001
RBIAS BAND >4.0 dBm typical input third-order intercept (IIP3)
14258-
>−10.6 dBm typical input 1 dB compression point (P1dB)
Figure 1.
Matched 50 Ω single-ended input Matched 100 Ω differential outputs 8-lead, 2.00 mm × 2.00 mm LFCSP microwave packaging APPLICATIONS Point to point microwave radios Instrumentation Satellite communications (SATCOM) Phased arrays GENERAL DESCRIPTION
The ADL5721 is a narrow-band, high performance, low noise performance that, in the past, required more expensive three- amplifier targeting microwave radio link receiver designs. The five (III-V) compounds process technology to achieve. This monolithic silicon germanium (SiGe) design is optimized for LNA uses a band switch feature to al ow the input P1dB and microwave radio link bands ranging from 5.9 GHz to 8.5 GHz. noise figure to trade off for optimum system performance. The unique design offers a single-ended 50 Ω input impedance The ADL5721 and ADL5723 to ADL5726 family of narrow- and provides a 100 Ω balanced differential output that is ideal band LNAs are each packaged in a tiny, thermally enhanced, for driving Analog Devices, Inc., differential downconverters 2.00 mm × 2.00 mm LFCSP package. The ADL5721 and and radio frequency (RF) sampling analog-to-digital converters ADL5723 to ADL5726 family operates over the temperature (ADCs). This low noise amplifier (LNA) provides noise figure range of −40°C to +85°C.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS LOW BAND (BAND = 0 V) HIGH BAND (BAND = 1.8 V) THEORY OF OPERATION APPLICATIONS INFORMATION LAYOUT DIFFERENTIAL vs. SINGLE-ENDED OUTPUT EVALUATION BOARD INITIAL SETUP RESULTS BASIC CONNECTIONS FOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
