Datasheet HMC1127 (Analog Devices) - 4
DescriptionGaAs, pHEMT, MMIC, High Gain Power Amplifier, 2 GHz to 50 GHz
Pages / Page16 / 4 — HMC1127. Data Sheet. 30 GHz TO 40 GHz FREQUENCY RANGE. Table 3. …
File Format / SizePDF / 391 Kb
HMC1127. Data Sheet. 30 GHz TO 40 GHz FREQUENCY RANGE. Table 3. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
HMC1127 Data Sheet 30 GHz TO 40 GHz FREQUENCY RANGE Table 3 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
TA = +25°C, VDD = +5 V, VGG2 = +1.4 V, IDD = 80 mA. Adjust VGG1 between −2 V and 0 V to achieve IDD = 80 mA typical.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 30 40 GHz GAIN 11.5 14.5 dB Gain Variation Over Temperature 0.011 dB/°C RETURN LOSS Input 20 dB Output 17 dB OUTPUT POWER 1 dB Compression (P1dB) P1dB 9 12 dBm Saturated Output Power (PSAT) PSAT 17 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 22 dBm NOISE FIGURE 6 dBm SUPPLY CURRENT IDD VDD = 4 V, VDD = 5 V, VDD = 6 V, VDD = 7 V, or VDD = 8 V 80 mA
40 GHz TO 50 GHz FREQUENCY RANGE
Table 4. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 40 50 GHz GAIN 11.5 14.5 dB Gain Variation Over Temperature 0.012 dB/°C RETURN LOSS Input 13 dB Output 13 dB OUTPUT POWER 1 dB Compression (P1dB) P1dB 8.5 10.5 dBm Saturated Output Power (PSAT) PSAT 15 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 18 dBm NOISE FIGURE 6.5 dBm SUPPLY CURRENT IDD VDD = 4 V, VDD = 5 V, VDD = 6 V, VDD = 7 V, or VDD = 8 V 80 mA Rev. B | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY 2 GHz TO 8 GHz FREQUENCY RANGE 8 GHz TO 30 GHz FREQUENCY RANGE 30 GHz TO 40 GHz FREQUENCY RANGE 40 GHz TO 50 GHz FREQUENCY RANGE ESD CAUTION INTERFACE SCHEMATICS MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS Handling Precautions Mounting Wire Bonding ASSEMBLY DIAGRAM ORDERING GUIDE
