Datasheet HMC1049SCPZ-EP (Analog Devices)
DescriptionGaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz
Pages / Page10 / 1 — GaAs, pHEMT, MMIC, Low Noise Amplifier,. 0.3 GHz to 20 GHz. Enhanced …
File Format / SizePDF / 267 Kb
GaAs, pHEMT, MMIC, Low Noise Amplifier,. 0.3 GHz to 20 GHz. Enhanced Product. HMC1049SCPZ-EP. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC1049SCPZ-EP Analog Devices
GaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz Enhanced Product HMC1049SCPZ-EP FEATURES FUNCTIONAL BLOCK DIAGRAM 1 Low noise figure: 2 dB C C C C C C C P1dB output power: 15 dBm NI NI ACG NI NI NI NI NI 32 31 30 29 28 27 26 25 PSAT output power: 17 dBm High gain: 14 dB NIC 1 HMC1049SCPZ-EP 24 NIC Output IP3: 23 dBm V 2 23 NIC DD Supply voltage: V NIC 3 22 GND DD = 7 V at 70 mA GND 4 21 RFOUT/VDD 50 Ω matched I/O RFIN 5 20 NIC 32-lead, 5 mm × 5 mm LFCSP package: 25 mm2 NIC 6 19 NIC NIC 7 18 NIC ENHANCED PRODUCT FEATURES NIC 8 17 NIC Supports defense and aerospace applications (AQEC standard) 9 10 11 12 13 14 15 16 Extended industrial temperature range: −55°C to +105°C C C C C C 3 2 GG NI NI NI NI NI V Controlled manufacturing baseline ACG ACG
002
1 assembly/test site NIC = NO INTERNAL CONNECTION
17190-
1 fabrication site
Figure 1.
Product change notification Qualification data available on request APPLICATIONS Radars Military communications Very small aperture terminals (VSATs) and satellite communications (SATCOM) Unmanned systems GENERAL DESCRIPTION
The HMC1049SCPZ-EP is a Gallium arsenide (GaAs), also be applied to Pin 21, although Pin 21 requires a bias tee monolithic microwave integrated circuit (MMIC), low noise with VDD = 4 V. The HMC1049SCPZ-EP amplifier amplifier (LNA) that operates between 0.3 GHz and 20 GHz. input/outputs (I/Os) are internal y matched to 50 Ω, and the This LNA provides 14 dB of small signal gain, 2 dB noise figure, device is supplied in a compact, leadless 5 mm × 5 mm LFCSP and an IP3 output of 23 dBm, yet requires only 70 mA from a package. 7 V supply. The P1dB output power of 15 dBm enables the LNA Additional application and technical information can be found to function as a local oscillator (LO) driver for balanced, in the HMC1049LP5E data sheet. inphase/quadrature (I/Q), or image rejection mixers. VDD can
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 0.3 GHZ TO 1 GHZ FREQUENCY RANGE 1 GHZ TO 14 GHZ FREQUENCY RANGE 14 GHZ TO 20 GHZ FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER DERATING CURVES ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
