Datasheet HMC1049LP5E (Analog Devices) - 3
DescriptionGaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz
Pages / Page14 / 3 — Data Sheet. HMC1049LP5E. SPECIFICATIONS. Table 1. Parameter. Min. Typ. …
File Format / SizePDF / 333 Kb
Data Sheet. HMC1049LP5E. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit
Data Sheet HMC1049LP5E SPECIFICATIONS Table 1 Parameter Min Typ Max Unit
TA = 25°C, VDD = 7 V, IDD = 70 mA1.
Table 1. Parameter Min Typ Max Min Typ Max Min Typ Max Unit
FREQUENCY RANGE 0.3 1 1 14 14 20 GHz GAIN 13.5 16.5 12 15 10 13 dB Gain Variation Over Temperature 0.006 0.019 0.017 dB/°C NOISE FIGURE 2.5 3.5 1.8 2.5 2.7 4.0 dB RETURN LOSS Input 15 13 14 dB Output 8 15 13 dB OUTPUT Output Power for 1 dB Compression (P1dB) 15 14.5 13 dBm Saturated (PSAT) 18 17.5 16 dBm Output Third-Order Intercept (IP3)2 31 29 26 dBm TOTAL SUPPLY CURRENT 70 70 70 mA 1 Adjust VGG between −2 V to 0 V to achieve IDD = 70 mA typical. 2 Measurement taken at POUT/tone = 8 dBm. Rev. B | Page 3 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Evaluation Printed Circuit Board Packaging and Ordering Information Outline Dimensions Ordering Guide
