14 /9 — Data Sheet. HMC1049. TA = +85°C. GAIN. TA = +25°C. POUT. TA = –55°C. PAE. …
Revision
B
PDF / 272 Kb
Data Sheet. HMC1049. TA = +85°C. GAIN. TA = +25°C. POUT. TA = –55°C. PAE. –10. ( AE. , P. –15. d N (. –20. TION. AI , G. OLA. –25. Bm) d (. –30. UT O. –35. –40. –12
Data SheetHMC1049020TA = +85°CGAINTA = +25°CPOUT–5TA = –55°CPAE16%)–10( AE), P–15dBB)(12d N (–20TIONAI , GOLA8–25ISBm) d (–30UT O4P–35–4000246810121416182022 024 –15–12–9–6–3036 027 FREQUENCY (GHz) 12956- INPUT POWER (dBm) 12956- Figure 22. Reverse Isolation vs. Temperature Figure 25. Power Compression at 18 GHz 2021NOISE FIGURE GAINBm)18dPSAT16(%) (AT SAE15), P, PdBB)12(d12INN ( AI), GA, G98dB (Bm)EdR(6UT O4PFIGU EGAIN3POISOUTNPAE00–15–12–9–6–3036 025 6.06.57.07.58.0 028 INPUT POWER (dBm) 12956- VDD (V) 12956- Figure 23. Power Compression at 2 GHz Figure 26. Noise Figure, Gain, and Power (PSAT) vs. Supply Voltage (VDD) at 12 GHz 2018NOISE FIGURE GAINBm) dP15SAT16%)((AT SAE), P, P12B)dB12d( INN ( AI9), GA, G8dB (Bm)Ed6(RUT O4PFIGU EGAIN3POUTOIS NPAE00–15–12–9–6–3036 026 50607080 029 INPUT POWER (dBm) 12956- IDD (mA) 12956- Figure 24. Power Compression at 10 GHz Figure 27. Noise Figure, Gain, and Power vs. Supply Current at 12 GHz Rev. B | Page 9 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution PIN Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Application Circuit Assembly Diagram Mounting and Bonding Techniques for Millimeterwave GaAs MMICs Handling Precautions Storage Cleanliness Static Sensitivity Transients General Handling Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding Outline Dimensions Ordering Guide
