Datasheet HMC1040LP3CE (Analog Devices) - 5
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 24 - 43.5 GHz
Pages / Page6 / 5 — HMC1040LP3CE. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 24 - 43.5 GHz. Pin …
File Format / SizePDF / 591 Kb
HMC1040LP3CE. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 24 - 43.5 GHz. Pin Descriptions. Application Circuit
HMC1040LP3CE GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 24 - 43.5 GHz Pin Descriptions Application Circuit
HMC1040LP3CE
v00.0112
Pin Number function Description interface schematic T m 1, 2, 4, These pins and package bottom must GND s 9, 11, 12 be connected to RF/DC ground. e - is This pin AC coupled 3 rfiN and matched to 50 ohms o w N The pins are not connected internally; however, all data 5-8, 14 N/C shown herein was measured with these pins connected to rf/ DC ground externally. lo s - This pin AC coupled 10 rfoUT and matched to 50 ohms r ie lif Drain bias voltages for the amplifier. See Application Circuit p 13, 15, 16 Vdd3, Vdd2, Vdd1 for required external componnets. m A
Application Circuit
Capacitor Value C1 - C3 100 pf C4 - C6 10 nf C7 - C9 4.7 µf Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
