Datasheet HMC962LC4 (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz
Pages / Page6 / 4 — HMC962LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 7.5 - 26.5 GHz. Current …
File Format / SizePDF / 374 Kb
HMC962LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 7.5 - 26.5 GHz. Current vs. Input Power @ 17 GHz. Absolute Maximum Ratings
HMC962LC4 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz Current vs Input Power @ 17 GHz Absolute Maximum Ratings
HMC962LC4
v02.0614
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz Current vs. Input Power @ 17 GHz Absolute Maximum Ratings
84 Drain Bias Voltage +4V 82 rf input power +10 dBm T Channel Temperature 150 °C 80 m Continuous pdiss (T = 85 °C) 0.39 w 78 (derate 5.97 mw/°C above 85 °C) s (mA) Thermal resistance Idd 76 167.6 °C/w (Channel to ground paddle) e - 74 storage Temperature -65 to +150 °C is 72 operating Temperature -40 to +85 °C o esD sensitivity (HBm) Class 1A 70 -8 -6 -4 -2 0 2 4 6 8 INPUT POWER (dBm) w N eleCTrosTATiC seNsiTiVe DeViCe lo oBserVe HANDliNG preCAUTioNs
Outline Drawing
s - r ie lif p m A NoTes: 1. pACKAGe BoDY mATeriAl: AlUmiNA. 2. leAD AND GroUND pADDle plATiNG: GolD flAsH oVer NiCKel. 3. DimeNsioNs Are iN iNCHes (millimeTers). 4. leAD spACiNG TolerANCe is NoN-CUmUlATiVe. 5. pACKAGe wArp sHAll NoT eXCeeD 0.05mm DATUm – C – 6. All GroUND leADs AND GroUND pADDle mUsT Be solDereD To pCB rf GroUND.
Package Information
part Number package Body material lead finish msl rating package marking [2] HmC962lC4 Alumina, white Gold over Nickel msl3 [1] H962 XXXX [1] max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
