Datasheet HMC902LP3E (Analog Devices)
Description5 GHz to 11 GHz GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page13 / 1 — 5 GHz to 11 GHz. GaAs, pHEMT, MMIC, Low Noise Amplifier. Data Sheet. …
RevisionE
File Format / SizePDF / 413 Kb
5 GHz to 11 GHz. GaAs, pHEMT, MMIC, Low Noise Amplifier. Data Sheet. HMC902LP3E. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC902LP3E Analog Devices, Revision: E
5 GHz to 11 GHz GaAs, pHEMT, MMIC, Low Noise Amplifier Data Sheet HMC902LP3E FEATURES FUNCTIONAL BLOCK DIAGRAM Low noise figure: 1.8 dB typical HMC902LP3E High gain: 19.5 dB 1 2 C C DD DD High P1dB output power: 16 dBm typical NI V V NI Single supply: 3.5 V at 80 mA 16 15 14 13 Output IP3: 28 dBm NIC 1 12 NIC 50 Ω matched input/output NIC 2 11 Self biased with optional bias control for quiescent drain NIC control (IDQ) reduction. RF 3 10 IN RFOUT 3 mm × 3 mm, 16-lead LFCSP: 9 mm² GND 4 9 GND APPLICATIONS 5 6 7 8 Point to point radios C 1 2 C PACKAGE NI GG GG NI BASE Point to multi point radios V V
001
GND Military and space
14524-
Test instrumentation
Figure 1.
GENERAL DESCRIPTION
The HMC902LP3E is a gallium arsenide (GaAs), pseudomorphic The P1dB output power of 16 dBm enables the LNA to function high electron mobility transistor (pHEMT), monolithic microwave as a local oscillator (LO) driver for balanced, I/Q, or image reject integrated circuit (MMIC) low noise amplifier (LNA), which is mixers. The HMC902LP3E also features inputs/outputs that are self biased with optional bias control for IDQ reduction. The dc blocked and internally matched to 50 Ω, making it ideal for HMC902LP3E is housed in a leadless 3 mm × 3 mm plastic surface high capacity microwave radios and C band, very small aperture mount package. The amplifier operates between 5 GHz and terminal (VSAT) applications. 11 GHz, providing 19.5 dB of small signal gain, 1.8 dB noise figure, and 28 dBm of output IP3, while requiring only 80 mA from a 3.5 V supply.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
