Datasheet ADL5523 (Analog Devices) - 4
Description400 MHz to 4000 MHz Low Noise Amplifier
Pages / Page21 / 4 — ADL5523. Data Sheet. DC SPECIFICATIONS. Table 2. 3 V. 5 V. Parameter. …
RevisionC
File Format / SizePDF / 685 Kb
ADL5523. Data Sheet. DC SPECIFICATIONS. Table 2. 3 V. 5 V. Parameter. Conditions. Min. Typ. Max. Unit
ADL5523 Data Sheet DC SPECIFICATIONS Table 2 3 V 5 V Parameter Conditions Min Typ Max Unit
ADL5523 Data Sheet DC SPECIFICATIONS Table 2. 3 V 5 V Parameter Conditions Min Typ Max Min Typ Max Unit
Supply Current 30 60 mA vs. Temperature −40°C ≤ TA ≤ +85°C ±4 ±7 mA
DE-EMBEDDED S-PARAMETERS, VPOS = 3 V TO 5 V, RFIN = PORT 1, VPOS = PORT 2, RFOUT = PORT 3 Table 3. Frequency S11 S12 S13 S21 S22 S23 S31 S32 S33 (GHz) (dB/Ang) (dB/Ang) (dB/Ang) (dB/Ang) (dB/Ang) (dB/Ang) (dB/Ang) (dB/Ang) (dB/Ang)
0.125 −4.2/−12.9 −37.1/−21.9 −40.6/+45.2 +19.3/+132 −6.2/+89.1 −10.6/+8.9 +15.9/−161 −10.5/−9.0 −8.6/−30.4 0.25 −5.8/−18.8 −40.0/−30.6 −38.3/+40.5 +15.4/+104 −2.3/+68.6 −13.2/−33.8 +16.6/+174 −13.2/−33.9 −11.0/−6.4 0.375 −7.6/−20.4 −42.0/−31.1 −37.5/+38.4 +11.4/+87.9 −1.1/+63.5 −16.2/−42.8 +16.0/+158.2 −16.2/−43.2 −11.3/+6.4 0.5 −9.5/−18.4 −43.9/−28.2 −36.7/+40.2 +7.6/+77.4 −0.6/+63.3 −19.0/−45.9 +14.9/+147 −19.0/−46.0 −11.7/+16.2 0.625 −11.4/−14.0 −46.5/−27.4 −36.2/+42.3 +3.84/+70.2 −0.3/+64.8 −21.7/−46.0 +13.8/+140 −21.7/−46.7 −12.1/+25.3 0.75 −13.2/−7.2 −48.8/−24.6 −35.8/+44.5 +0.0/+65.3 −0.2/+66.5 −24.6/+45.6 +12.8/+135 −24.5/−45.8 −12.5/+34.3 0.875 −15.1/+2.3 −51.1/−19.3 −35.4/+47.8 −4.2/+62.6 −0.1/+68.0 −27.8/−42.8 +11.8/+132 −27.8/−44.5 −12.8/+43.2 1.0 −16.8/+13.9 −56.6/−17.6 −35.1/+51.1 −9.7/+61.7 +0.0/+68.5 −32.3/−40.3 +10.9/+129 −32.5/−42.4 −13.1/+52.3 1.125 −18.2/+27.3 −64.4/−15.8 −34.6/+53.9 −19.0/+70.9 +0.1/+67.5 −41.4/−31.5 +10.1/+127 −41.6/−38.6 −13.4/+60.8 1.25 −19.3/+42.3 −66.5/−173 −34.5/+56.7 −22.0/−161 +0.2/+66.0 −45.0/+118 +9.3/+126 −42.8/+129 −13.6/+69.3 1.375 −19.9/+57.4 −56.2/+160 −34.1/+60.1 −13.6/−147 +0.3/+63.4 −34.3/+130 +8.6/+125 −33.8/+132 −13.9/+77.5 1.5 −20.0/+71.1 −52.2/+153 −33.9/+63.1 −10.2/−147 +0.4/+61.1 −30.0/+133 +7.9/+124 −29.8/+133 −14.0/+85.3 1.625 −20.2/+82.7 −49.0/+165 −33.5/+66.2 −8.5/−148 +0.5/+61.1 −27.5/+134 +7.3/+125 −27.2/+134 −14.2/+92.8 1.75 −20.1/+92.5 −46.7/+160 −33.3/+70.3 −7.4/−149 +0.6/+62.8 −25.9/+137 +6.8/+124 −25.5/+135 −14.4/+100 1.875 −19.9/+101 −45.3/+167 −32.9/+72.5 −6.8/−148 +0.6/+67.4 −24.5/+139 +6.3/+124 −24.2/+139 −14.5/+107 2.0 −19.7/+107 −44.6/+173 −32.6/+75.1 −6.4/−147 +0.6/+73.6 −23.5/+142 +5.8/+125 −23.3/+143 −14.6/+114 2.125 −19.6/+113 −43.5/+176 −32.1/+78.2 −6.1/−144 +0.7/+82.7 −22.7/+148 +5.4/+125 −22.5/+148 −14.7/+121 2.25 −19.3/+116 −42.3/−180 −31.7/+80.6 −6.0/−140 +0.7/+93.9 −22.0/+154 +5.0/+125 −21.8/+154 −14.8/+127 2.375 −19.0/+117 −41.8/−172 −31.5/+83.1 −5.9/−135 +0.7/+107 −21.3/+161 +4.7/+125 −21.1/+161 −14.8/+133 2.5 −18.6/+117 −41.2/−166 −31.1/+84.7 −5.7/−129 +0.7/+122 −20.6/+169 +4.3/+125 −20.5/+169 −14.8/+140 2.625 −18.1/+118 −40.0/−156 −30.8/+86.7 −5.6/−122 +0.7/+139 −20.0/+178 +4.0/+125 −19.8/+178 −14.8/+145 2.75 −17.5/+117 −39.3/−146 −30.4/+89.0 −5.4/−115 +0.7/+158 −19.3/−173 +3.6/+125 −19.1/−172 −14.7/+151 2.875 −16.8/+118 −38.6/−136 −30.3/+90.4 −5.1/−106 +0.8/+178 −18.6/+162 +3.3/+125 −18.5/−162 −14.7/+158 3.0 −15.9/+117 −37.6/−126 −30.0/+91.7 −5.0/−97.7 +0.8/−161 −18.0/−152 +2.9/+125 −17.8/−152 −14.7/+164 3.125 −14.9/+118 −37.1/−115 −29.8/+92.0 −4.9/−88.5 +0.7/−138 −17.5/−141 +2.6/+124 −17.3/−140 −14.5/+172 3.25 −13.9/+120 −36.5/−105 −29.4/+92.3 −4.9/−79.2 +0.5/−116 −16.8/−129 +2.2/+123 −16.7/−130 −14.4/+180 3.375 −13.0/+121 −35.8/−95.4 −29.3/+92.2 −4.7/−71.8 +0.1/−95.2 −16.3/−121 +1.7/+122 −16.2/−121 −14.0/−172 3.5 −12.0/+124 −35.1/−88.7 −29.3/+92.3 −4.4/−66.4 −0.3/−76.7 −15.4/−115 +1.2/+120 −15.3/−115 −13.4/−162 3.625 −11.3/+127 −33.7/−85.0 −29.6/+91.2 −3.6/−63.6 −0.8/−60.6 −14.2/−111 +0.4/+118 −14.1/−111 −12.4/−152 3.75 −10.7/+131 −31.4/−86.9 −30.5/+89.4 −1.9/−67.1 −1.7/−47.8 −12.1/−114 −0.9/+116 −11.9/−113 −10.8/−141 3.875 −10.4/+138 −28.6/−99.9 −32.9/+95.9 +0.7/−83.0 −4.9/−35.8 −8.9/−129 −3.9/+124 −8.8/−129 −7.9/−137 4.0 −9.3/+152 −27.3/−136 −30.9/+132 +1.3/−120 −6.3/+42.3 −7.8/−164 −1.4/+155 −7.7/−165 −5.8/−150 Rev. C | Page 4 of 21 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DC SPECIFICATIONS DE-EMBEDDED S-PARAMETERS, VPOS = 3 V TO 5 V, RFIN = PORT 1, VPOS = PORT 2, RFOUT = PORT 3 ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 900 MHz, VPOS = 5 V 1950 MHZ, VPOS = 5 V 2600 MHz, VPOS = 5 V 3500 MHz, VPOS = 5 V 900 MHz, VPOS = 3 V 1950 MHz, VPOS = 3 V 2600 MHz, VPOS = 3 V 3500 MHz, VPOS = 3 V DC CHARACTERISTICS BASIC CONNECTIONS EVALUATION BOARD SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN TUNING THE ADL5523 FOR OPTIMAL NOISE FIGURE TUNING S22 TUNING THE LNA INPUT FOR OPTIMAL GAIN TUNING THE LNA INPUT FOR OPTIMAL NOISE FIGURE S11 OF THE LNA WITH S22 MATCHED OUTLINE DIMENSIONS ORDERING GUIDE
