Datasheet ADL5523 (Analog Devices) - 5
Description400 MHz to 4000 MHz Low Noise Amplifier
Pages / Page21 / 5 — Data Sheet. ADL5523. ABSOLUTE MAXIMUM RATINGS. ESD CAUTION. Table 4. …
RevisionC
File Format / SizePDF / 685 Kb
Data Sheet. ADL5523. ABSOLUTE MAXIMUM RATINGS. ESD CAUTION. Table 4. Parameter Rating
Data Sheet ADL5523 ABSOLUTE MAXIMUM RATINGS ESD CAUTION Table 4 Parameter Rating
Data Sheet ADL5523 ABSOLUTE MAXIMUM RATINGS ESD CAUTION Table 4. Parameter Rating
Supply Voltage, VPOS 5.5 V RF Input Level 7 dBm RF Input Level (with 8 Ω Series Resistor on VPOS) 20 dBm Internal Power Dissipation 500 mW θJA (Junction to Air) 50°C/W Maximum Junction Temperature 150°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. C | Page 5 of 21 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DC SPECIFICATIONS DE-EMBEDDED S-PARAMETERS, VPOS = 3 V TO 5 V, RFIN = PORT 1, VPOS = PORT 2, RFOUT = PORT 3 ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 900 MHz, VPOS = 5 V 1950 MHZ, VPOS = 5 V 2600 MHz, VPOS = 5 V 3500 MHz, VPOS = 5 V 900 MHz, VPOS = 3 V 1950 MHz, VPOS = 3 V 2600 MHz, VPOS = 3 V 3500 MHz, VPOS = 3 V DC CHARACTERISTICS BASIC CONNECTIONS EVALUATION BOARD SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN TUNING THE ADL5523 FOR OPTIMAL NOISE FIGURE TUNING S22 TUNING THE LNA INPUT FOR OPTIMAL GAIN TUNING THE LNA INPUT FOR OPTIMAL NOISE FIGURE S11 OF THE LNA WITH S22 MATCHED OUTLINE DIMENSIONS ORDERING GUIDE
