Datasheet ADL5523 (Analog Devices) - 7
Description400 MHz to 4000 MHz Low Noise Amplifier
Pages / Page21 / 7 — Data Sheet. ADL5523. TYPICAL PERFORMANCE CHARACTERISTICS 900 MHz, VPOS = …
RevisionC
File Format / SizePDF / 685 Kb
Data Sheet. ADL5523. TYPICAL PERFORMANCE CHARACTERISTICS 900 MHz, VPOS = 5 V. 2.0. S21. 1.8. 1.6. 1.4. 1.2. RS E. S11. 1.0. –10. 0.8. ARA. –15. S22. 0.6
Data Sheet ADL5523 TYPICAL PERFORMANCE CHARACTERISTICS 900 MHz, VPOS = 5 V 2.0 S21 1.8 1.6 1.4 1.2 RS E S11 1.0 –10 0.8 ARA –15 S22 0.6
Matched for optimal noise figure, external matching circuit included.
25 2.0 20 S21 1.8 15 1.6 10 B) 1.4 d 5 B) ( (d 0 1.2 RS E S11 RE T U E –5 1.0 IG M F –10 E 0.8 ARA IS -P –15 S NO S22 0.6 –20 0.4 –25 S12 –30 0.2 –35 0 600 650 700 750 800 850 900 950 1000 1050 1100 1150 1200
03 06 0
800 820 840 860 880 900 920 940 960 980 1000
0 9- 9-
FREQUENCY (MHz)
82
FREQUENCY (MHz)
82 06 06 Figure 3. Typical S-Parameters, Log Magnitude Figure 6. Noise Figure vs. Frequency at 25°C, Multiple Devices
24 60 23.5 36 22 GAIN 55 +25°C +85°C 23.0 34 20 50 B) 22.5 32 d 18 45 ) –40°C OIP3 ) N ( 16 40 AI Bm 22.0 –40°C 30 Bm OIP3 d d 14 35 ) B ( B 21.5 +25°C 28 B ( d AND G 1d 1d 12 30 P ( P D IN A 21.0 26 D URE 10 25 G +85°C IG P1dB 3 AN GAIN 3 AN F 8 20 20.5 –40°C P1dB 24 E IP IP IS O O 6 15 NO 20.0 22 4 10 19.5 +25°C 20 2 5 NOISE FIGURE +85°C 0 0 19.0 18 850 860 870 880 890 900 910 920 930 940 950
04 07 0
0 9- 9-
FREQUENCY (MHz)
82
FREQUENCY (MHz)
82 06 06 Figure 4. Noise Figure, Gain, OIP3, and P1dB vs. Frequency Figure 7. Gain, OIP3, and P1dB vs. Temperature
2.0 40 1.8 38 +25°C 1.6 36 1.4 34 –40°C B) (d 1.2 +85°C ) 32 RE m U B 1.0 d IG 30 3 ( F +25°C E +85°C 0.8 IS OIP 28 NO –40°C 0.6 26 0.4 24 0.2 22 0 20
8
050
–4 –2 0 2 4 6 8 10 12 14 16 18 20 22
00 9- 9-
FREQUENCY (MHz)
82
P
82 06
OUT PER TONE (dBm)
06 Figure 5. Noise Figure vs. Temperature Figure 8. OIP3 vs. Output Power (POUT) and Temperature Rev. C | Page 7 of 21 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DC SPECIFICATIONS DE-EMBEDDED S-PARAMETERS, VPOS = 3 V TO 5 V, RFIN = PORT 1, VPOS = PORT 2, RFOUT = PORT 3 ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 900 MHz, VPOS = 5 V 1950 MHZ, VPOS = 5 V 2600 MHz, VPOS = 5 V 3500 MHz, VPOS = 5 V 900 MHz, VPOS = 3 V 1950 MHz, VPOS = 3 V 2600 MHz, VPOS = 3 V 3500 MHz, VPOS = 3 V DC CHARACTERISTICS BASIC CONNECTIONS EVALUATION BOARD SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN TUNING THE ADL5523 FOR OPTIMAL NOISE FIGURE TUNING S22 TUNING THE LNA INPUT FOR OPTIMAL GAIN TUNING THE LNA INPUT FOR OPTIMAL NOISE FIGURE S11 OF THE LNA WITH S22 MATCHED OUTLINE DIMENSIONS ORDERING GUIDE
