Datasheet HMC-ALH476 (Analog Devices)
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 14 - 27 GHz
Pages / Page6 / 1 — HMC-ALH476. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 14 - 27 GHz. Typical …
File Format / SizePDF / 274 Kb
HMC-ALH476. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 14 - 27 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC-ALH476 Analog Devices
HMC-ALH476
v02.0209
1
Typical Applications Features
This HMC-ALH476 is ideal for: Noise Figure: < 2 dB @ 20 GHz IP • Point-to-Point Radios Gain: 20 dB H • Point-to-Multi-Point Radios P1dB Output Power: +14 dBm C • Military & Space Supply Voltage: +4V @ 90 mA - • Test Instrumentation Die Size: 2.25 x 1.58 x 0.1 mm RS IE IF L P
M The HMC-ALH476 is a GaAs MMIC HEMT Low Noise A Wideband Amplifi er die which operates between 14 E and 27 GHz. The amplifi er provides 20 dB of gain, 2 IS dB noise fi gure and +14 dBm of output power at 1 dB O gain compression while requiring only 90 mA from a N +4V supply voltage. The HMC-ALH476 amplifi er is ideal for integration into Multi-Chip-Modules (MCMs) W due to its small size. O L
Electrical Specifi cations, T = +25° C, Vdd= +4V A
Parameter Min. Typ. Max. Min. Typ. Max. Units Frequency Range 14 - 18 18 - 27 GHz Gain 18 20 18 20 dB Gain Variation over Temperature 0.02 0.02 dB / °C Noise Figure 2.5 3 2 2.6 dB Input Return Loss 16 17 dB Output Return Loss 18 20 dB Output Power for 1 dB Compression 14 14 dBm Supply Current (Idd) (Vdd = 4V, Vgg = -0.3V Typ.) 90 90 mA *Unless otherwise indicated, all measurements are from probed die Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 198
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
