Datasheet HMC566LP4E (Analog Devices)
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 28 - 36 GHz
Pages / Page6 / 1 — HMC566LP4E. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 28 - 36 GHz. Typical …
File Format / SizePDF / 417 Kb
HMC566LP4E. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 28 - 36 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC566LP4E Analog Devices
HMC566LP4E
v02.0609
7
Typical Applications Features
T The HmC566lp4e is ideal for: low Noise figure: 2.8 dB m • point-to-point radios High Gain: 21 dB s • point-to-multi-point radios & VsAT High oip3: +24 dBm • Test equipment and sensors single positive supply: +3V @ 82 mA e - • military & space 50 ohm matched & DC Blocked i/os is o 24 lead 4x4mm QfN package: 16mm² w N
lo The HmC566lp4e is a high dynamic range GaAs pHemT mmiC low Noise Amplifier (lNA) in a s - 4x4 mm smT package which operates from 28 to r 36 GHz. The HmC566lp4e provides 21 dB of small ie signal gain, 2.8 dB of noise figure and output ip3 of 24 dBm. This self-biased lNA is ideal for hybrid and lif mCm assemblies due to its compact size, single p +3V supply operation, and DC blocked rf i/o’s. m The roHs packaged HmC566lp4e eliminates the A need for wirebonding and al ows the use of high volume surface mount manufacturing techniques. The HmC566lp4e is also available in chip form as the HmC566.
Electrical Specifications, T = +25° C, Vdd 1, 2, 3, 4 = +3V A
parameter min. Typ. max. min. Typ. max. min. Typ. max. Units frequency range 28 - 31.5 31.5 - 33.5 33.5 - 36 GHz Gain 18 21 19.5 22.5 18 21 dB Gain Variation over Temperature 0.03 0.03 0.03 dB/ °C Noise figure 2.8 3.6 2.8 3.6 3.3 4.3 dB input return loss 14 18 12 dB output return loss 8 10 7 dB output power for 1 dB Compression (p1dB) 11 12 11 dBm saturated output power (psat) 13 14 13 dBm output Third order intercept (ip3) 23.5 24.5 24.5 dBm supply Current (idd1+idd2+idd3+idd4) 50 82 106 50 82 106 50 82 106 mA Info F rmoatri op n rfiurcne is ,h ed d ebly ivAe n r al y o g aDn evdic eto s i p s bla eli c evee d otro dbe e ras: cc uH ratite tiatne d M reli iac bl reo . w Ho av wev e er , Cno o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No O P r h d o e ne r O : 7 n 81- -3li 2n 9 e - 4 a 7 t 0 ww 0 • O w rd .h e it r o tniltie n .c e ao t m
7 - 1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p li coarti o ap n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
