Datasheet HMC566 (Analog Devices)
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 29 - 36 GHz
Pages / Page6 / 1 — HMC566. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 29 - 36 GHz. Typical …
File Format / SizePDF / 337 Kb
HMC566. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 29 - 36 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC566 Analog Devices
HMC566
v00.0306
1
Typical Applications Features
The HMC566 is ideal for use as a LNA or driver ampli- Noise Figure: 2.8 dB IP fi er for: Gain: 20 dB H • Point-to-Point Radios OIP3: 23.5 dBm C • Point-to-Multi-Point Radios & VSAT - Single Supply: +3V @ 80 mA • Test Equipment and Sensors 50 Ohm Matched Input/Output RS • Military & Space Small Size: 2.54 x 0.98 x 0.10 mm IE IF L P
M The HMC566 is a high dynamic range GaAs PHEMT A MMIC Low Noise Amplifi er (LNA) chip which operates E from 29 to 36 GHz. The HMC566 provides 20 dB of IS small signal gain, 2.8 dB of noise fi gure and output O IP3 of 23.5 dBm across the operating band. This self- biased LNA is ideal for hybrid and MCM assemblies N due to its compact size, slightly positive gain slope, W single +3V supply operation, and DC blocked RF I/O’s. O All data is measured with the chip in a 50 Ohm test L fi xture connected via two 0.025 mm (1 mil) diameter bondwires of minimal length 0.31 mm (12 mil).
Electrical Specifi cations, T = +25° C, Vdd 1, 2, 3, 4 = +3V A
Parameter Min. Typ. Max. Min. Typ. Max. Units Frequency Range 29 - 33 33 - 36 GHz Gain 17 20 19 22 dB Gain Variation Over Temperature 0.03 0.05 0.03 0.05 dB/ °C Noise Figure 2.8 3.3 2.8 3.3 dB Input Return Loss 15 15 dB Output Return Loss 9 8 dB Output Power for 1 dB Compression (P1dB) 9 12 9 12 dBm Saturated Output Power (Psat) 14.5 14.5 dBm Output Third Order Intercept (IP3) 23.5 23.5 dBm Supply Current (Idd)(Vdd = +3V) 80 80 mA Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 90
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
