Datasheet HMC562 (Analog Devices) - 6
DescriptionGaAs PHEMT MMIC WIDEBAND DRIVER AMPLIFIER, 2 - 35 GHz
Pages / Page8 / 6 — HMC562. GaAs PHEMT MMIC WIDEBAND. DRIVER AMPLIFIER, 2 - 35 GHz. Pad …
File Format / SizePDF / 403 Kb
HMC562. GaAs PHEMT MMIC WIDEBAND. DRIVER AMPLIFIER, 2 - 35 GHz. Pad Descriptions. 2 - 39
HMC562 GaAs PHEMT MMIC WIDEBAND DRIVER AMPLIFIER, 2 - 35 GHz Pad Descriptions 2 - 39
HMC562
v04.1108
Pad Number Function Description Interface Schematic This pad is AC coupled 2 1 IN and matched to 50 Ohms Power supply voltage for amplifi er. 2 Vdd IP External bypass capacitors are required. H This pad is AC coupled 3 OUT and matched to 50 Ohms - C Gate control for amplifi er. External S bypass capacitors are required. 4 Vgg R Please follow “MMIC Amplifi er Biasing Procedure” application note. IE IF Die Bottom GND Die bottom must be connected to RF/DC ground. L P M K A OC BL IN A & G R E IV R D Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
2 - 39
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
