Datasheet HMC374, 374E (Analog Devices) - 4
DescriptionSMT PHEMT LOW NOISE AMPLIFIER, 0.3 - 3.0 GHz
Pages / Page6 / 4 — HMC374 / 374E. SMT PHEMT LOW NOISE. AMPLIFIER, 0.3 - 3.0 GHz. Absolute …
File Format / SizePDF / 326 Kb
HMC374 / 374E. SMT PHEMT LOW NOISE. AMPLIFIER, 0.3 - 3.0 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC374 / 374E SMT PHEMT LOW NOISE AMPLIFIER, 0.3 - 3.0 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC374 / 374E
v00.0405
8
Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +7.0 Vdc Vdd (V) Idd (mA) RF Input Power (RFIN)(Vdd = +5.0 Vdc) 15 dBm 2.7 89 T Channel Temperature 150 °C 3.0 89 Continuous Pdiss (T = 85 °C) 5.0 90 0.488 W (derate 7.5 mW/°C above 85 °C) 5.5 90 - SM Thermal Resistance 133 °C/W S (channel to lead) R Storage Temperature -65 to +150 °C ELECTROSTATIC SENSITIVE DEVICE Operating Temperature -40 to +85 °C OBSERVE HANDLING PRECAUTIONS IE IF L P
Outline Drawing
M E A IS W NO O L NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY 2. DIMENSIONS ARE IN INCHES [MILLIMETERS] 3. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.15mm PER SIDE. 4. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.25mm PER SIDE. 5. ALL GROUND LEADS MUST BE SOLDERED TO PCB RF GROUND.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [3] [1] H374 HMC374 Low Stress Injection Molded Plastic Sn/Pb Solder MSL1 XXXX [2] 374E HMC374E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 XXXX [1] Max peak refl ow temperature of 235 °C [2] Max peak refl ow temperature of 260 °C [3] 4-Digit lot number XXXX Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Pho - n 25 e: 7 0- 81 33 2 4 9- 3 F 470 ax: 978 0 • Order o - n 25 lin 0 e a-t 3373 www.analog.com
8 - 63
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
