Datasheet HMC516 (Analog Devices)
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 7 - 17 GHz
Pages / Page6 / 1 — HMC516. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 7 - 17 GHz. Typical …
File Format / SizePDF / 579 Kb
HMC516. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 7 - 17 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC516 Analog Devices
HMC516
v03.1017
GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 7 - 17 GHz Typical Applications Features
Noise Figure: 1.8 dB The HMC516 is ideal for use as a LNA or driver ampli- Gain: 20 dB IP fier for: H OIP3: +20 dBm • Point-to-Point Radios Single Supply: 3V @ 65 mA • Point-to-Multi-Point Radios & VSAT 50 Ohm Matched Input/Output • Test Equipment and Sensors E - C Die Size: 2.52 x 1.32 x 0.1 mm • Military & Space IS O
The HMC516 chip is a high dynamic range GaAs W N PHEMT MMIC Low Noise Amplifier (LNA) which O covers the 7 to 17 GHz frequency range. The HMC516 provides 20 dB of small signal gain, 1.8 dB of noise figure and has an output IP3 greater than +20 dBm. S - L The chip can easily be integrated into hybrid or MCM R assemblies due to its small size. All data is tested IE with the chip in a 50 Ohm test fixture connected via 0.075mm (3 mil) ribbon bonds of minimal length 0.31 LIF mm (12 mil). Two 0.025 mm (1 mil) diameter bondwires P may also be used to make the RFIN and RFOUT M connections. A
Electrical Specifications, T = +25° C, Vdd 1, 2, 3 = +3V A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 7 - 9 9 - 12 12 - 17 GHz Gain 17 19.5 18 20.5 18 20.5 dB Gain Variation Over Temperature 0.02 0.03 0.02 0.03 0.02 0.03 dB/ °C Noise Figure 2.5 3.3 2.0 2.6 1.8 2.3 dB Input Return Loss 8 10 10 dB Output Return Loss 13 15 17 dB Output Power for 1 dB Compression (P1dB) 10 13 12 15 13 16 dBm Saturated Output Power (Psat) 15 16 17 dBm Output Third Order Intercept (IP3) 20 20 20 dBm Supply Current (Idd)(Vdd = +3V) 65 88 65 88 65 88 mA Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
