Datasheet HMC490LP5, 490LP5E (Analog Devices) - 3
DescriptionGaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz
Pages / Page8 / 3 — HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - …
File Format / SizePDF / 419 Kb
HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 16 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC490LP5 / 490LP5E GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz P1dB vs Temperature Psat vs Temperature
HMC490LP5 / 490LP5E
v04.0213
GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz P1dB vs. Temperature Psat vs. Temperature
32 32 T 28 28 M 24 24 20 20 (dBm) 16 (dBm) 16 R - S P1dB 12 Psat 12 IE 8 8 4 4 LIF 0 0 10 11 12 13 14 15 16 17 18 10 11 12 13 14 15 16 17 18 P FREQUENCY (GHz) FREQUENCY (GHz) M +25 C +85 C -40 C +25 C +85 C -40 C E A
Gain, Noise Figure & OIP3 vs.
IS
Supply Voltage @ 14 GHz, Idd= 200 mA Power Compression @ 14 GHz
O 40 5 30 (%) 25 36 4 W N ) N O PAE I 20 (dBm S 32 3 E (dB), F LO IP3 IG 15 U GAIN 28 2 R (dB), E (d 10 B GAIN ) (dBm), 24 1 5 Pout 20 0 0 3.5 4 4.5 5 5.5 -20 -15 -10 -5 0 5 10 Vdd (V) INPUT POWER (dBm) Gain IP3 Pout Gain PAE Noise Figure
Gain, Noise Figure & IP3 vs. Supply Current @ 14 GHz, Vdd= 5V* Power Dissipation
40 5 2 1.8 36 4 ) (W) NOISE 1.6 (dBm 1.4 32 3 IP3 FIGURE 1.2 28 2 DISSIPATION (dB), 1 (dB) GAIN 0.8 24 1 POWER 0.6 20 0 0.4 3.5 4 4.5 5 5.5 -20 -15 -10 -5 0 5 10 Vdd (V) INPUT POWER (dBm) Gain IP3 Max Pdis @ 85C 14 GHz 12 GHz 15 GHz 13 GHz 16 GHz Noise Figure * Idd is controlled by varying Vgg Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
