Datasheet HMC490LP5, 490LP5E (Analog Devices) - 6
DescriptionGaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz
Pages / Page8 / 6 — HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - …
File Format / SizePDF / 419 Kb
HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 16 GHz. Pin Descriptions. Application Circuit
HMC490LP5 / 490LP5E GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz Pin Descriptions Application Circuit
HMC490LP5 / 490LP5E
v04.0213
Pin Number Function Description Interface Schematic 1, 2, 6 - 12, The pins are not connected internally; however, all data T 14 - 19, 23, 24, N/C shown herein was measured with these pins connected to 26, 27, 29 - 31 RF/DC ground externally. M Package bottom must also 3, 5, 20, 22 GND be connected to RF/DC ground. R - S This pad is AC coupled 4 RFIN IE and matched to 50 Ohms. LIF P Gate control for amplifier. Adjust to achieve Idd of 200 mA. Please follow “MMIC Amplifier Biasing Procedure” M 13 Vgg Application Note. External bypass capacitors of 100 pF and 0.01 µF are required. E A This pad is AC coupled IS 21 RFOUT and matched to 50 Ohms. O Power Supply Voltage for the amplifier. External bypass 25, 28, 32 Vdd3, 2, 1 capacitors of 100 pF and 0.01 µF are required. W N LO
Application Circuit
Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
