Datasheet HMC490LP5, 490LP5E (Analog Devices) - 7
DescriptionGaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz
Pages / Page8 / 7 — HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - …
File Format / SizePDF / 419 Kb
HMC490LP5 / 490LP5E. GaAs pHEMT MMIC LOW NOISE. HIGH IP3 AMPLIFIER, 12 - 16 GHz. Evaluation PCB
HMC490LP5 / 490LP5E GaAs pHEMT MMIC LOW NOISE HIGH IP3 AMPLIFIER, 12 - 16 GHz Evaluation PCB
HMC490LP5 / 490LP5E
v04.0213
T M R - S IE LIF P M E A IS O W N LO
List of Materials for Evaluation PCB 108402 [1]
The circuit board used in the application should use Item Description RF circuit design techniques. Signal lines should J1 - J2 PCB Mount SMA Connector have 50 Ohm impedance while the package ground J3 - J8 DC Pin leads and package bottom should be connected C1 - C4 1000 pF Capacitor, 0402 Pkg. directly to the ground plane similar to that shown. C5 - C8 4.7 µF Capacitor, Tantalum A sufficient number of via holes should be used U1 HMC490LP5 / HMC490LP5E to connect the top and bottom ground planes. PCB [2] 108540 Evaluation PCB The evaluation board should be mounted to an [1] Reference this number when ordering complete evaluation PCB appropriate heat sink. The evaluation circuit board [2] Circuit Board Material: Rogers 4350 shown is available from Hittite upon request. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
