Datasheet HMC462LP5, 462LP5E (Analog Devices) - 6
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz
Pages / Page6 / 6 — HMC462LP5 / 462LP5E. GAAS PHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. …
File Format / SizePDF / 378 Kb
HMC462LP5 / 462LP5E. GAAS PHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. Evaluation PCB
HMC462LP5 / 462LP5E GAAS PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz Evaluation PCB
HMC462LP5 / 462LP5E
v05.0213
T M E - S IS O W N O S - L R IE LIF P M A
List of Materials for Evaluation PCB 108338 [1]
The circuit board used in the application should use Item Description RF circuit design techniques. Signal lines should J1 - J2 PCB Mount SMA Connector have 50 Ohm impedance while the package ground J3 2 mm Molex Header leads and package bottom should be connected C1 100 pF Capacitor, 0402 Pkg. directly to the ground plane similar to that shown. C2 1000 pF Capacitor, 0603 Pkg. A sufficient number of via holes should be used C3 4.7 µF Capacitor, Tantalum to connect the top and bottom ground planes. U1 HMC462LP5 / HMC462LP5E The evaluation board should be mounted to an PCB [2] 109751 Evaluation PCB appropriate heat sink. The evaluation circuit board [1] Reference this number when ordering complete evaluation PCB shown is available from Hittite upon request. [2] Circuit Board Material: Rogers 4350 Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
