Datasheet HMC342LC4 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz
Pages / Page6 / 3 — HMC342LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 13 - 25 GHz. P1dB vs. …
File Format / SizePDF / 343 Kb
HMC342LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 13 - 25 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC342LC4 GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz P1dB vs Temperature Psat vs Temperature
HMC342LC4
v04.0514
GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz P1dB vs. Temperature Psat vs. Temperature
14 14 T 12 12 M 10 10 8 8 (dBm) (dBm) S - S 6 6 P1dB +25 C Psat R +85 C 4 +25 C +85 C 4 -40 C IE -40 C 2 2 LIF 0 0 P 12 14 16 18 20 22 24 26 12 14 16 18 20 22 24 26 FREQUENCY (GHz) FREQUENCY (GHz) M E A
Power Compression @ 20 GHz Reverse Isolation vs. Temperature
IS 24 0 O (%) 19 -10 PAE ) Pout +25 C W N 14 -20 Gain +85 C PAE (dB -40 C (dB), N IO 9 -30 T LO GAIN LA O 4 IS -40 (dBm), -1 -50 Pout -6 -60 -26 -24 -22 -20 -18 -16 -14 -12 -10 -8 -6 -4 12 14 16 18 20 22 24 26 INPUT POWER (dBm) FREQUENCY (GHz)
Gain, Power & Noise Figure vs. Supply Voltage @ 20 GHz
24 (dB) 20 FIGURE Gain 16 P1dB Psat NOISE Noise Figure 12 sat (dBm), ), P 8 m dB ( 4 1dB ), P dB 0 ( IN 2.7 3 3.3 A G Vdd Supply Voltage (Vdc) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
