Datasheet HMC342LC4 (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz
Pages / Page6 / 4 — HMC342LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 13 - 25 GHz. Absolute …
File Format / SizePDF / 343 Kb
HMC342LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 13 - 25 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC342LC4 GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC342LC4
v04.0514
GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +5.5 Vdc Vdd (Vdc) Idd (mA) RF Input Power (RFIN)(Vdd = +3.0 Vdc) 0 dBm +2.7 42 T Channel Temperature 175 °C +3.0 43 M Continuous Pdiss (T= 85 °C) +3.3 44 0.326 W (derate 3.62 mW/°C above 85 °C) Note: Amplifier will operate over full voltage ranges shown above. Thermal Resistance 276 °C/W (channel to ground paddle) S - S Storage Temperature -65 to +150 °C R Operating Temperature -40 to +85 °C ELECTROSTATIC SENSITIVE DEVICE IE OBSERVE HANDLING PRECAUTIONS LIF P
Outline Drawing
M E A IS O W N LO NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA. 2. LEAD AND GROUND PADDLE PLATING: GOLD FLASH OVER NICKEL. 3. DIMENSIONS ARE IN INCHES (MILLIMETERS). 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. 5. PACKAGE WARP SHALL NOT EXCEED 0.05MM DATUM – C – 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC342LC4 Alumina, White Gold over Nickel MSL3 [1] H342 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
