Datasheet HMC263 (Analog Devices)
DescriptionGaAs MMIC LOW NOISE AMPLIFIER, 24 - 36 GHz
Pages / Page7 / 1 — HMC263. GaAs MMIC LOW NOISE. AMPLIFIER, 24 - 36 GHz. Typical …
File Format / SizePDF / 615 Kb
HMC263. GaAs MMIC LOW NOISE. AMPLIFIER, 24 - 36 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC263 Analog Devices
HMC263
v05.1017
GaAs MMIC LOW NOISE AMPLIFIER, 24 - 36 GHz Typical Applications Features
The HMC263 is ideal for: Excel ent Noise Figure: 2 dB IP • Mil imeterwave Point-to-Point Radios Gain: 22 dB H • LMDS Single Supply: +3V @ 58 mA • VSAT Small Size: 2.48 x 1.33 x 0.1 mm E - C • SATCOM IS O
The HMC263 chip is a GaAs MMIC Low Noise W N Amplifier (LNA) which covers the frequency range of O 24 to 36 GHz. The chip can easily be integrated into Multi-Chip Modules (MCMs) due to its small (3.29 mm2) size. The chip utilizes a GaAs PHEMT process S - L offering 22 dB gain from a single bias supply of + 3V R @ 58 mA with a noise figure of 2.0 dB. All data is with IE the chip in a 50 ohm test fixture connected via 0.076 mm (3 mil) diameter ribbon bonds of minimal length LIF 0.31 mm (<12 mils). The HMC263 may be used in P conjunction with HMC264 or HMC265 mixers to real- M ize a mil imeterwave system receiver. A
Electrical Specifications, T = +25° C, Vdd = +3V A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 24 - 27 27 - 32 32 - 36 GHz Gain 20 23 26 18 22 26 17 20 23 dB Gain Variation Over Temperature 0.03 0.04 0.03 0.04 0.03 0.04 dB/°C Noise Figure 2.5 3.3 2.0 2.5 2.1 2.6 dB Input Return Loss 7 10 7 10 7 10 dB Output Return Loss 7 10 9 12 8 11 dB Output Power for 1 dB Compression (P1dB) -1 3 1 5 4 8 dBm Saturated Output Power (Psat) 1 5 3 7 6 10 dBm Output Third Order Intercept (IP3) 5 10 7 13 11 17 dBm Supply Current (Idd) (@ Vdd = +3.0V) 58 77 58 77 58 77 mA Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
2
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
