Datasheet ADPA7005CHIP (Analog Devices) - 8
DescriptionGaAs, pHEMT, MMIC,1 W Power Amplifier, 20 GHz to 44 GHz
Pages / Page23 / 8 — ADPA7005CHIP. Data Sheet. +85°C +25°C –55°C. –10. URN L. –15. INP. UT O. …
File Format / SizePDF / 522 Kb
ADPA7005CHIP. Data Sheet. +85°C +25°C –55°C. –10. URN L. –15. INP. UT O. –20. 1600mA 1400mA 1200mA. –25. FREQUENCY (GHz). 1600mA 1400mA. 1200mA
ADPA7005CHIP Data Sheet +85°C +25°C –55°C –10 URN L –15 INP UT O –20 1600mA 1400mA 1200mA –25 FREQUENCY (GHz) 1600mA 1400mA 1200mA
ADPA7005CHIP Data Sheet 0 0 +85°C +25°C –55°C –5 –5 B) B) d d ( ( S S S S O O –10 –10 URN L URN L T T –15 RE –15 RE UT UT P INP UT O –20 –20 1600mA 1400mA 1200mA –25 –25 20 22 24 26 28 30 32 34 36 38 40 42 44
016
019
FREQUENCY (GHz)
17319-
FREQUENCY (GHz)
17319- Figure 16. Input Return Loss vs. Frequency for Various IDQ, VDD = 5 V Figure 19. Output Return Loss vs. Frequency for Various Temperature, VDD = 5 V, IDQ = 1200 mA
0 0 1600mA 1400mA –5 1200mA –5 B) B) d d ( ( S S S –10 S O O –10 URN L –15 URN L T T RE RE –15 UT UT P –20 P UT UT O O –20 –25 4V 5V –30 –25 20 22 24 26 28 30 32 34 36 38 40 42 44
017
020
FREQUENCY (GHz)
17319-
FREQUENCY (GHz)
17319- Figure 17. Output Return Loss vs Frequency for Various VDD, IDQ = 1200 mA Figure 20. Output Return Loss vs. Frequency for Various IDQ, VDD = 5 V
0 12 +85°C +85°C +25°C +25°C –10 –55°C 10 –55°C ) B –20 (d ) N 8 dB IO ( T E A –30 R L 6 SO –40 FIGU E SE I OIS N 4 EVER –50 R 2 –60 –70 0 20 22 24 26 28 30 32 34 36 38 40 42 44
018
021
FREQUENCY (GHz)
17319-
FREQUENCY (GHz)
17319- Figure 18. Reverse Isolation vs. Frequency for Various Temperatures, Figure 21. Noise Figure vs. Frequency for Various Temperatures, VDD = 5 V, VDD = 5 V, IDQ = 1200 mA IDQ = 1200 mA Rev. 0 | Page 8 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 34 GHz FREQUENCY RANGE 34 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTIC CONSTANT IDD OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding BIASING ADPA7005CHIP WITH THE HMC980LP4E APPLICATION CIRCUIT SETUP LIMITING VGATE FOR ADPA7005CHIP VGGx ABSOLUTE MAXIMUM RATING REQUIREMENT HMC980LP4E BIAS SEQUENCE Power-Up Sequence Power-Down Sequence CONSTANT DRAIN CURRENT BIASING vs. CONSTANT GATE VOLTAGE BIASING TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
