Datasheet ADTR1107 (Analog Devices) - 10
Description6 GHz to 18 GHz, Front-End IC
Pages / Page28 / 10 — ADTR1107. Data Sheet. –10. +85°C. +25°C. –40°C. –20. R O. –30. ACT. –40. …
File Format / SizePDF / 943 Kb
ADTR1107. Data Sheet. –10. +85°C. +25°C. –40°C. –20. R O. –30. ACT. –40. –50. –60. –70. RP CL. –80. –90. 10 11 12 13 14 15 16 17 18 19 20. FREQUENCY (GHz)
ADTR1107 Data Sheet –10 +85°C +25°C –40°C –20 R O –30 ACT –40 –50 –60 –70 RP CL –80 –90 10 11 12 13 14 15 16 17 18 19 20 FREQUENCY (GHz)
ADTR1107 Data Sheet 0 36 34 –10 +85°C +25°C ) +85°C 32 B +25°C –40°C –40°C –20 (d 30 B) R O (d 28 N –30 ACT 26 IO F AT –40 G 24 L IN O L 22 P IS –50 U E 20 O RS C 18 E –60 V UT 16 RE _O –70 14 RP CL 12 –80 10 –90
8
8
1
5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
-01
-02
FREQUENCY (GHz)
146 146 22
FREQUENCY (GHz)
22 Figure 18. Reverse Isolation vs. Frequency for Various Temperatures,Transmit Figure 21. CLPR_OUT Coupling Factor vs. Frequency for Various State, Path = TX_IN to ANT, VDD_PA = 5 V, IDQ_PA = 220 mA, Receive State Off Temperatures, Transmit State, Coupling Factor = ANT POUT − CPLR_OUT POUT, VDD_PA = 5 V, IDQ_PA = 220 mA, Receive State Off
0 0 +85°C –10 +85°C –10 B) +25°C +25°C B) (d –40°C –40°C (d –20 N –20 N IO IO AT –30 L AT O L –30 O IS –40 IS UT UT _O –40 –50 _O RX O RX –60 T –50 O T _IN –70 X T ANT –60 –80 –70
9
–90
2
-01
-02
FREQUENCY (GHz)
146 146 22
FREQUENCY (GHz)
22 Figure 19. TX_IN to RX_OUT Isolation vs. Frequency for Various Temperatures, Figure 22. ANT to RX_OUT Isolation vs. Frequency for Various Temperatures, Transmit State, VDD_PA = 5 V, IDQ_PA = 220 mA, Receive State Off Transmit State, VDD_PA = 5 V, IDQ_PA = 220 mA, Receive State Off
16 16 +85°C 5.0V 14 +25°C 14 4.0V –40°C 3.3V ) ) 12 dB 12 dB ( ( E E R R U U G 10 G 10 FI FI E E IS IS O 8 O N 8 N 6 6 4
0
4
3
-02
-02
FREQUENCY (GHz)
146 146 22
FREQUENCY (GHz)
22 Figure 20. Noise Figure vs. Frequency for Various Temperatures, Transmit Figure 23. Noise Figure vs. Frequency for Various VDD_PA, Transmit State, State, Path = TX_IN to ANT, VDD_PA = 5 V, IDQ_PA = 220 mA, Receive State Off Path = TX_IN to ANT, IDQ_PA = 220 mA, Receive State Off Rev. A | Page 10 of 28 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS TRANSMIT STATE RECEIVE STATE THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCING TYPICAL APPLICATION CIRCUIT INTERFACING THE ADTR1107 TO THE ADAR1000 X BAND AND KU BAND BEAMFORMER OUTLINE DIMENSIONS ORDERING GUIDE
