Datasheet HMC8205BF10 (Analog Devices) - 10
Description0.3 GHz to 6 GHz, 35 W, GaN Power Amplifier
Pages / Page14 / 10 — HMC8205BF10. Data Sheet. 300MHz. 1GHz. 2GHz. Bm). 3GHz. d (. 4GHz. 5GHz. …
RevisionC
File Format / SizePDF / 262 Kb
HMC8205BF10. Data Sheet. 300MHz. 1GHz. 2GHz. Bm). 3GHz. d (. 4GHz. 5GHz. INT O. 6GHz. N P. S S. 28V. (dB 3. 40V. 45V. 50V. 55V. B CO. FREQUENCY (GHz)
HMC8205BF10 Data Sheet 300MHz 1GHz 2GHz Bm) 3GHz d ( 4GHz 5GHz INT O 6GHz N P S S 28V (dB 3 40V 45V 50V 55V B CO FREQUENCY (GHz)
HMC8205BF10 Data Sheet 50 70 300MHz 48 1GHz 60 2GHz 46 Bm) 3GHz d ( 4GHz 44 50 5GHz INT O 6GHz 42 N P 40 ) IO c 40 S S 28V (dB 3 30 RE 38 40V P D M 45V IM 36 50V 20 55V B CO 34 4d 10 32 30 0
039
0 1 2 3 4 5 6 20 25 30 35 40
048
FREQUENCY (GHz)
13790-
OUTPUT POWER (dBm)
13790- Figure 33. 4 dB Compression Point vs. Frequency at Various Supply Voltages Figure 36. Upper Third-Order Intermodulation (IMD3) vs. Output Power at Various Frequencies
55 4.5 B) d ( 4.0 +85°C INT +25°C O 50 3.5 –40°C P T P 3.0 mA) RCE 45 ( E 2.5 NT NT R I +85°C 2.0 +25°C RDE 40 CURRE 1.5 O –40°C E AT RD- G 1.0 HI T 35 0.5 UT P 0 UT O 30 –0.5 0 1 2 3 4 5 6
046
10 15 20 25 30 35
049
FREQUENCY (GHz)
13790-
INPUT POWER (dBm)
13790- Figure 34. Output Third-Order Intercept Point vs. Frequency at 32 dBm Figure 37. Gate Current vs. Input Power at Various Temperatures Output Power at Various Temperatures
60 4.0 B) d ( 55 3.5 INT O P 50 A) T 3.0 ( P NT 45 RCE 2.5 E NT 300MHz 40 CURRE R I Y 2.0 1GHz L P 2GHz RDE 35 O 3GHz UP 1.5 4GHz N S RD- HI 30 5GHz 1.0 T 6GHz DRAI UT P 25 0.5 UT O 20 0 20 25 30 35 40
047 050
–6.0 –5.0 –5.0 –4.5 –4.0 –3.5 –3.0 –2.5 –2.0 –1.5 –1.0 OUTPUT POWER PER TONE (dBm) GATE VOLTAGE (V)
13790- 13790- Figure 35. Output Third-Order Intercept Point vs. Output Power per Tone at Figure 38. Drain Supply Current vs. Gate Voltage Various Frequencies Rev. C | Page 10 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Application Circuit Evaluation PCB Outline Dimensions Ordering Guide
