Datasheet HMC1114 (Analog Devices) - 7
Description10 W, GaN Power Amplifier, 2.7 GHz to 3.8 GHz
Pages / Page15 / 7 — Data Sheet. HMC1114. P1dB. P4dB. (dBm). dBm). SAT AT PIN = 16dBm. B (. …
File Format / SizePDF / 320 Kb
Data Sheet. HMC1114. P1dB. P4dB. (dBm). dBm). SAT AT PIN = 16dBm. B (. +85°C. +25°C. P O. P4d. –40°C. 2.6. 2.8. 3.0. 3.2. 3.4. 3.6. 3.8. 4.0. FREQUENCY (GHz)
Data Sheet HMC1114 P1dB P4dB (dBm) dBm) SAT AT PIN = 16dBm B ( +85°C +25°C P O P4d –40°C 2.6 2.8 3.0 3.2 3.4 3.6 3.8 4.0 FREQUENCY (GHz)
Data Sheet HMC1114 44 44 42 42 40 40 38 P1dB P4dB 38 (dBm) P dBm) SAT AT PIN = 16dBm UT B ( +85°C 36 36 +25°C P O P4d –40°C 34 34 32 32 30 30 2.6 2.8 3.0 3.2 3.4 3.6 3.8 4.0
014
017
FREQUENCY (GHz)
13530-
FREQUENCY (GHz)
13530- Figure 14. Output Power (POUT) vs. Frequency, Figure 17. Output Power for 4 dB Compression (P4dB) vs. Frequency at Measurement Taken at PIN = 16 dBm Various Temperatures
44 44 42 42 40 40 38 38 dBm) B ( (dBm) +85°C 36 36 +25°C P4d 32V 28V P SAT –40°C 25V 34 20V 34 32 32 30 30 2.6 2.8 3.0 3.2 3.4 3.6 3.8 4.0
015
018
FREQUENCY (GHz)
13530-
FREQUENCY (GHz)
13530- Figure 15. Output Power for 4 dB Compression (P4dB) vs. Frequency at Figure 18. Saturated Output Power (PSAT) vs. Frequency at Various Various Supply Voltages Temperatures, Measurement Taken at PIN = 16 dBm
44 44 42 42 40 40 38 38 dBm) (dBm) B ( 300mA 36 32V 36 225mA P SAT 28V P4d 150mA 25V 100mA 34 20V 34 32 32 30 30 2.6 2.8 3.0 3.2 3.4 3.6 3.8 4.0
016
019
FREQUENCY (GHz)
13530-
FREQUENCY (GHz)
13530- Figure 16. Saturated Output Power (PSAT) vs. Frequency at Various Supply Figure 19. Output Power for 4 dB Compression (P4dB) vs. Frequency at Voltages, Measurement Taken at PIN = 16 dBm Various Supply Currents Rev. A | Page 7 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS TOTAL SUPPLY CURRENT BY VDD ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCE During Power-Up During Power-Down TYPICAL APPLICATION CIRCUIT EVALUATION PRINTED CIRCUIT BOARD (PCB) BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
