Datasheet HMC1114 (Analog Devices) - 9
Description10 W, GaN Power Amplifier, 2.7 GHz to 3.8 GHz
Pages / Page15 / 9 — Data Sheet. HMC1114. 3.8GHz. 3.25GHz. 2.7GHz. dBc). 3 (. PUT. POUT/TONE …
RevisionA
File Format / SizePDF / 320 Kb
Data Sheet. HMC1114. 3.8GHz. 3.25GHz. 2.7GHz. dBc). 3 (. PUT. POUT/TONE (dBm). OUT/TONE (dBm). 1000. POUT. 900. GAIN. PAE. 800. (%). IDD. 700. , P. 600. dB). N (
Data Sheet HMC1114 3.8GHz 3.25GHz 2.7GHz dBc) 3 ( PUT POUT/TONE (dBm) OUT/TONE (dBm) 1000 POUT 900 GAIN PAE 800 (%) IDD 700 , P 600 dB) N (
Data Sheet HMC1114 50 50 45 3.8GHz 3.8GHz 3.25GHz 45 3.25GHz 2.7GHz 2.7GHz 40 40 35 dBc) 35 dBc) 3 ( 3 ( IM 30 IM 30 PUT PUT 25 UT 25 UT O O 20 20 15 15 10 10 15 17 19 21 23 25 27 29 31 33 35
028
029
POUT/TONE (dBm) P
13530-
OUT/TONE (dBm)
13530- Figure 26. Output Third-Order Intermodulation (IM3) vs. POUT/Tone at VDD = 25 V Figure 29. Output Third-Order Intermodulation (IM3) vs. POUT/Tone at VDD = 32 V
50 60 1000 45 3.8GHz POUT 900 3.25GHz GAIN 2.7GHz 50 PAE 800 40 (%) IDD AE 700 35 , P dBc) 40 600 3 ( dB) IM 30 N ( 500 AI (mA) PUT , G I DD 25 30 400 UT O (dBm) 300 20 UTPO 20 200 15 100 10 10 0 15 17 19 21 23 25 27 29 31 33 35
026
–4 0 4 8 12 16 20 24
030
POUT/TONE (dBm) INPUT POWER (dBm)
13530- 13530- Figure 27. Output Third-Order Intermodulation (IM3) vs. POUT/Tone at VDD = 28 V Figure 30. Output Power (POUT), Gain, Power Added Efficiency (PAE), and Supply Current (IDD) vs. Input Power at 3.2 GHz
60 1500 60 1000 POUT 1350 POUT 900 GAIN GAIN 50 PAE 1200 50 PAE 800 (%) IDD (%) IDD AE 1050 AE 700 , P , P 40 900 dB) 40 600 dB) N ( N ( 750 AI (mA) 500 AI (mA) , G I DD , G I DD 30 600 30 400 (dBm) 450 (dBm) 300 UT UT P O 20 300 P O 20 200 150 100 10 0 10 0 –4 0 4 8 12 16 20 24
027
031
INPUT POWER (dBm) INPUT POWER (dBm)
13530- 13530- Figure 28. Output Power (POUT), Gain, Power Added Efficiency (PAE), and Figure 31. Output Power (POUT), Gain, Power Added Efficiency (PAE), and Supply Current (IDD) vs. Input Power at 2.7 GHz Supply Current (IDD) vs. Input Power at 3.8 GHz Rev. A | Page 9 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS TOTAL SUPPLY CURRENT BY VDD ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCE During Power-Up During Power-Down TYPICAL APPLICATION CIRCUIT EVALUATION PRINTED CIRCUIT BOARD (PCB) BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
