15 /10 — HMC1114. Data Sheet. –10. +85°C. +25°C. –40°C. –20. (dBm). (d N. SAT, P. …
Revision
A
PDF / 320 Kb
HMC1114. Data Sheet. –10. +85°C. +25°C. –40°C. –20. (dBm). (d N. SAT, P. TIO. –30. dBm). B (. –40. SE I. , P. P1dB. EVER. –50. dB). P4dB. N (. PSAT AT PIN = 16dBm. –60
HMC1114Data Sheet045–10+85°C+25°C)–40°C40B–20(dBm)(d NSAT, PTIO35–30LAdBm)SOB (–40SE I4d30, PP1dBEVER–50dB)P4dBRN (PSAT AT PIN = 16dBmAI25–60G–70202.62.83.03.23.43.63.84.0 032 2425262728 035 FREQUENCY (GHz) 13530- VDD (V) 13530- Figure 32. Reverse Isolation vs. Frequency at Various Temperatures Figure 35. Gain, P4dB, and PSAT vs. Supply Voltage (VDD) at 3.2 GHz 4520183.8GHz40163.25GHz(dBm))2.7GHzSAT(W14N, P35TIO12dBm)PAB (10ISSI4d30D, P8P1dBERdB)P4dBW6N (PSAT AT PIN = 16dBmPOAI25G42201001502002503000 033 0510152025 036 IDD (mA) 13530- INPUT POWER (dBm) 13530- Figure 33. Gain, Output Power for 4 dB Compression (P4dB), and Saturated Figure 36. Power Dissipation vs. Input Power at 85°C Output Power (PSAT) vs. Supply Current (IDD) 804070+85°C35+25°C–40°C6030dBc) C (25)50NI OE (%20PA40+85°C15ND HARM+25°C–40°C30SECO102051002.62.83.03.23.43.63.84.0 034 2.62.83.03.23.43.63.84.0 037 FREQUENCY (GHz) 13530- FREQUENCY (GHz) 13530- Figure 34. Power Added Efficiency (PAE) vs. Frequency at Various Figure 37. Second Harmonic vs. Frequency at Various Temperatures, Temperatures, PIN = 16 dBm POUT = 30 dBm Rev. A | Page 10 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS TOTAL SUPPLY CURRENT BY VDD ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCE During Power-Up During Power-Down TYPICAL APPLICATION CIRCUIT EVALUATION PRINTED CIRCUIT BOARD (PCB) BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
