Datasheet HMC952ALP5GE (Analog Devices) - 3
DescriptionGaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz
Pages / Page10 / 3 — HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR …
File Format / SizePDF / 844 Kb
HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR 8 - 14 GHz. Psat vs. Temperature
HMC952ALP5GE GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz Psat vs Temperature
HMC952ALP5GE
v03.0418
GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz Psat vs. Temperature Psat vs. Supply Voltage
38 38 T 36 36 m 34 34 s ) m m (dB 32 (dB 32 at at s s P P r - 30 30 e 28 28 w 26 26 o 8 9 10 11 12 13 14 8 9 10 11 12 13 14 p FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -40 C 5V 6V r & A e
P1dB vs. Supply Current Psat vs. Supply Current
38 38 lin 36 36 s - ) 34 34 m ) m r (dB 32 (dB 32 at 1dB s P ie P 30 30 28 28 lif p 26 26 8 9 10 11 12 13 14 8 9 10 11 12 13 14 m FREQUENCY (GHz) FREQUENCY (GHz) A 1200 mA 1300 mA 1400 mA 1200 mA 1300 mA 1400 mA
Output IP3 vs. Temperature, Output IP3 vs. Supply Current, Pout/tone = +20 dBm Pout/tone = +20 dBm
46 46 44 44 42 42 ) 40 ) 40 m m (dB 38 (dB 38 3 3 IP IP 36 36 34 34 32 32 30 30 8 9 10 11 12 13 14 8 9 10 11 12 13 14 FREQUENCY (GHz) FREQUENCY (GHz) +25 C +85 C -40 C 1200 mA 1300 mA 1400 mA For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Output IP3 vs. Vdd @ Pout = 18 dBm Tone Power Compression @ 4 GHz Power Compression @ 10 GHz Power Compression @ 20 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Reverse Isolation vs Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
