Datasheet HMC952ALP5GE (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz
Pages / Page10 / 4 — HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR …
File Format / SizePDF / 844 Kb
HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR 8 - 14 GHz. Output IP3 vs. Supply Voltage,
HMC952ALP5GE GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz Output IP3 vs Supply Voltage,
HMC952ALP5GE
v03.0418
GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz Output IP3 vs. Supply Voltage, Output IM3 @ Vdd = +5V Pout/tone = +20 dBm
46 80 44 70 42 60 T ) 40 ) 50 c m m (dB 38 (dB 40 s 3 3 IP IM 36 30 34 20 r - 32 10 e 30 0 w 8 9 10 11 12 13 14 14 16 18 20 22 24 26 28 30 32 FREQUENCY (GHz) Pout/TONE (dBm) o p 8.5 GHz 11.5 GHz 5V 6V 9.5 GHz 12.5 GHz 10.5 GHz 13.5 GHz r & A
Output IM3 @ Vdd = +6V Power Compression @ 8.5 GHz
e 80 40 2000 70 ) 35 1900 % ( lin 60 E 30 1800 A ) 50 ), P c 25 1700 B d Idd (dB ( 40 in 1600 ( s - 3 20 a m IM A 30 ), G 1500 ) r 15 m B 20 d 10 1400 t ( ie u o 10 P 5 1300 0 0 1200 lif 14 16 18 20 22 24 26 28 30 32 -9 -7 -5 -3 -1 1 3 5 7 p Pout/TONE (dBm) INPUT POWER (dBm) m Idd 8.5 GHz 11.5 GHz A 9.5 GHz 12.5 GHz 10.5 GHz 13.5 GHz Pout Gain PAE
Power Compression @ 11 GHz Power Compression @ 13.5 GHz
40 2200 40 2200 ) 35 2075 ) 35 2075 % % ( E 1950 E 30 30 1950 A A ), P 1825 ), P 25 25 1825 B B d Idd d Idd ( in 20 1700 ( in 20 1700 ( a m a m A A ), G ) 15 1575 ), G ) 15 1575 m m B B d d 10 1450 10 1450 t ( t ( u u o o P 5 1325 P 5 1325 0 1200 0 1200 -9 -7 -5 -3 -1 1 3 5 7 -10 -8 -6 -4 -2 0 2 4 6 INPUT POWER (dBm) INPUT POWER (dBm) Idd Idd Pout Gain PAE Pout Gain PAE For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
4
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Output IP3 vs. Vdd @ Pout = 18 dBm Tone Power Compression @ 4 GHz Power Compression @ 10 GHz Power Compression @ 20 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Reverse Isolation vs Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
