HMC952ALP5GE v03.0418 GaAs pHEMT MMIC 2 Watt POWER AMPLIFIERWITH POWER DETECTOR 8 - 14 GHzDetector Voltage vs. Frequency & TemperatureReverse Isolation vs. Temperature 10 0 T -10 1 m -20 ) B -30 s ) d ( 0.1 N t (V -40 e IO d T A -50 f-V L r - re 0.01 O V IS -60 e -70 0.001 w -80 -90 o 0.0001-10 1 12 23 34 8 9 10 11 12 13 14 p OUTPUT POWER (dBm) FREQUENCY (GHz) 10 GHz +25 C 12 GHz +25 C 10 GHz +85 C 12 GHz +85 C +25 C +85 C -40 C 10 GHz -40 C 12 GHz -40 C r & A Gain & Power vs.Gain & Power vs. e Supply Current @ 11.5 GHzSupply Voltage @ 11.5 GHz 40 40 ) lin ) m m (dB 36 (dB 36 at s at s s - ), P ), P m 32 m 32 r (dB (dB 1dB 28 ie 1dB 28 ), P ), P (dB (dB 24 n n 24 lif ai ai G G p 20 20 1200 1250 1300 1350 1400 5 5.2 5.4 5.6 5.8 6 m Idd (mA) Vdd (V) A GAIN P1dB Psat GAIN P1dB Psat Power Dissipation 12 ) 10 (W N IO 8 PAT 6 ISSI D ER 4 W PO 2 0 -10 -8 -6 -4 -2 0 2 4 6 8 INPUT POWER (dBm) 8 GHz 12 GHz 9 GHz 13 GHz 10 GHz 14 GHz 11 GHz For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com 5 Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Output IP3 vs. Vdd @ Pout = 18 dBm Tone Power Compression @ 4 GHz Power Compression @ 10 GHz Power Compression @ 20 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Reverse Isolation vs Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
