Datasheet HMC1099 (Analog Devices) - 4
Description>10 W, GaN Power Amplifier, 0.01 GHz to 1.1 GHz
Pages / Page16 / 4 — HMC1099. Data Sheet. Table 3. Parameter. Symbol. Min. Typ. Max. Unit. …
File Format / SizePDF / 395 Kb
HMC1099. Data Sheet. Table 3. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
HMC1099 Data Sheet Table 3 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
HMC1099 Data Sheet
TA = 25°C, VDD = 28 V, IDD = 100 mA, frequency range = 0.7 GHz to 1.1 GHz.
Table 3. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.7 1.1 GHz GAIN Small Signal Gain 16.5 18.5 dB Gain Flatness ±0.5 dB RETURN LOSS Input 12 dB Output 17 dB POWER Output Power for 4 dB Compression P4dB 41.5 dBm Power Gain for P4dB Compression 14 dB Saturated Output Power PSAT 41.5 dBm >10 W saturated output power Power Gain for PSAT 13.5 dB Power Added Efficiency PAE 69 % OUTPUT THIRD-ORDER INTERCEPT IP3 47 dBm Measurement taken at POUT/tone = 30 dBm NOISE FIGURE 5 dB TOTAL SUPPLY CURRENT IDD 100 mA Adjust the gate bias control voltage (VGG) between −8 V to 0 V to achieve an IDD = 100 mA typical
TOTAL SUPPLY CURRENT BY VDD Table 4. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
SUPPLY CURRENT IDD Adjust the gate bias control voltage (VGG) between −8 V to 0 V to achieve an IDD = 100 mA typical VDD = 24 V 100 mA VDD = 28 V 100 mA Rev. A | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS TOTAL SUPPLY CURRENT BY VDD ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT EVALUATION PCB BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
