Datasheet HMC1144 (Analog Devices) - 4
Description35 GHz to 70 GHz, GaAs, pHEMT, MMIC, Medium Power Amplifier
Pages / Page16 / 4 — HMC1144. Data Sheet. 50 GHz TO 70 GHz FREQUENCY RANGE. Table 3. Parameter …
RevisionD
File Format / SizePDF / 351 Kb
HMC1144. Data Sheet. 50 GHz TO 70 GHz FREQUENCY RANGE. Table 3. Parameter Symbol. Test. Conditions/Comments. Min. Typ. Max. Unit
HMC1144 Data Sheet 50 GHz TO 70 GHz FREQUENCY RANGE Table 3 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
TA = 25°C, VDD = VDD1A = VDD2A = VDD3A = VDD4A = 4 V, IDD = IDD1A + IDD2A + IDD3A + IDD4A = 320 mA, unless otherwise stated. Adjust VGG1B from −2 V to 0 V to achieve IDD = 320 mA typical.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 50 70 GHz GAIN 17 19 dB Gain Variation Over Temperature 0.016 dB/°C RETURN LOSS Input 22 dB Output 25 dB OUTPUT Output Power for 1 dB Compression P1dB 19 21 dBm Saturated Output Power PSAT 22 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 32 dBm SUPPLY CURRENT Total Supply Current IDD 320 mA Total Supply Current vs. VDD IDD = 290 mA 4 V IDD = 320 mA 4 V IDD = 350 mA 4 V Rev. D | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY ELECTRICAL SPECIFICATIONS 35 GHz TO 40 GHz FREQUENCY RANGE 40 GHz TO 50 GHz FREQUENCY RANGE 50 GHz TO 70 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION ALTERNATE BIASING CONFIGURATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
