Datasheet HMC7229 (Analog Devices) - 5
Description33 GHz to 40 GHz, GaAs, pHEMT, MMIC, 1 W Power Amplifier with Power Detector
Pages / Page16 / 5 — Data Sheet. HMC7229. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter. Rating. …
RevisionD
File Format / SizePDF / 310 Kb
Data Sheet. HMC7229. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter. Rating. ESD CAUTION
Data Sheet HMC7229 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
Data Sheet HMC7229 ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Drain Bias Voltage (VDD) 7 V stress rating only; functional operation of the product at these RF Input Power (RFIN) 21 dBm or any other conditions above those indicated in the operational Channel Temperature 175°C section of this specification is not implied. Operation beyond Continuous Power Dissipation (PDISS), 9.7 W the maximum operating conditions for extended periods may TA = 85°C (Derate 107 mW/°C Above 85°C) affect product reliability. Thermal Resistance, θJC (Channel to 9.3°C/W
ESD CAUTION
Bottom Die) Storage Temperature Range −65°C to +150°C Operating Temperature Range −55°C to +85°C ESD Sensitivity, Human Body Model (HBM) Class 0, passed 150 V Rev. D | Page 5 of 16 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications 33 GHz to 35 GHz Frequency Range 35 GHz to 37 GHz Frequency Range 37 GHz to 40 GHz Frequency Range Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Typical Application Circuit Mounting and Bonding Techniques for Millimeter Wave GaAs MMICs Handling Precautions Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding Assembly Diagram Outline Dimensions Ordering Guide
