Datasheet HMC7149 (Analog Devices) - 3
Description10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz
Pages / Page10 / 3 — HMC7149. 10 WATT GaN MMIC POWER AMPLIFIER,. 6 - 18 GHz. P4dB vs. …
File Format / SizePDF / 944 Kb
HMC7149. 10 WATT GaN MMIC POWER AMPLIFIER,. 6 - 18 GHz. P4dB vs. Temperature. P4dB vs. Supply Voltage. Psat vs. Temperature
HMC7149 10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz P4dB vs Temperature P4dB vs Supply Voltage Psat vs Temperature
HMC7149
v
10 WATT GaN MMIC POWER AMPLIFIER, 6 - 18 GHz P4dB vs. Temperature P4dB vs. Supply Voltage
IP 45 45 H 40 40 R - C 35 35 E P4dB (dBm) P4dB (dBm) W 30 30 O 25 25 6 8 10 12 14 16 18 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY (GHz) R & P +25C +85C -40C 24V 28V 32V A E IN
Psat vs. Temperature Psat vs. Supply Voltage
50 50 S - L R 45 45 IE 40 40 Psat (dBm) Psat (dBm) LIF P 35 35 M A 30 30 6 8 10 12 14 16 18 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY (GHz) +25C +85C -40C 24V 28V 32V
P4dB vs. Supply Current Psat vs. Supply Curent
50 45 45 40 40 35 Psat (dBm) P4dB (dBm) 35 30 30 25 6 8 10 12 14 16 18 6 8 10 12 14 16 18 FREQUENCY (GHz) FREQUENCY (GHz) 340 mA 680 mA 1360 mA 340 mA 680 mA 1360 mA FIo nf r p orm raiticoe n , d fur e nislihvee d rby a y A n n d t alog o p Devila ce cs e o is b rd eli e ev res d : A to n b a e lao ccg D urat e e v anic d eresli, I abl n e c . .H, 1 Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 owever, no For price, delivery, and to place orders: Analog Devices, In c., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
3
Phone: 781-329-4700 • Order On-line at www.analog.com rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
