Datasheet HMC7357LP5GE (Analog Devices) - 8
DescriptionGaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 5.5 - 8.5 GHz
Pages / Page10 / 8 — HMC7357LP5GE. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 5.5 - 8.5 GHz. …
File Format / SizePDF / 728 Kb
HMC7357LP5GE. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 5.5 - 8.5 GHz. Application Circuit. Vdd1. C22. 4.7uF. 10nF. 100pF. Vdd2. Vgg1
HMC7357LP5GE GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 5.5 - 8.5 GHz Application Circuit Vdd1 C22 4.7uF 10nF 100pF Vdd2 Vgg1
HMC7357LP5GE
v01.0918
T
Vdd1
M
C22 C4 C3 4.7uF 10nF 100pF R1 Vdd2
R - S
Vgg1
E
43.2 Ohm C16 C15 C27 C21 C1 C2 100pF 10nF 4.7uF
W
4.7uF 10nF 100pF
O
24 23 22 21 20 19
R & P
1 18
A
2 17
E
J1 J2
IN
RFIN 3 16 RFOUT 4 15 1.5KΩ 1.5KΩ
S - L
5 14
R IE
6 13 1 7 8 9 10 1 12
LIF P M A
Vgg2 R2 43.2 Ohm
000
C30 C20 C19 4.7uF 10nF 100pF Vdd4
00000-
C9 C10 C25 100pF 10nF 4.7uF Vdd3 C28 C11 C12 4.7uF 10nF 100pF
For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
8
Document Outline Typical Applications Features General Description Functional Diagram Electrical Specifications Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature P1dB vs Supply Voltage Output IP3 vs. Supply Voltage, Pout/tone = +20 dBm Output IM3 @ Vdd = +6V Output IM3 @ Vdd =+7V Output IM3 @ Vdd = +8V Power Compression @ 6 GHz Power Compression @ 7 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Package Information Application Circuit List of Materials for Evaluation PCB EV1HMC7357LP5 [1] Evaluation PCB Pin Descriptions Gain & Power vs. Supply Current @ 7 GHz Gain & Power vs. Supply Voltage @ 7 GHz Power Compression @ 8 GHz Reverse Isolation vs. Temperature Output IP3 vs. Temperature, Pout/tone = +20 dBm Output IP3 vs. Supply Current, Pout/tone = +20 dBm P1dB vs. Supply Current Psat vs. Supply Current Psat vs. Temperature Psat vs. Supply Voltage
