Datasheet HMC7357LP5GE (Analog Devices) - 9
DescriptionGaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 5.5 - 8.5 GHz
Pages / Page10 / 9 — HMC7357LP5GE. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 5.5 - 8.5 GHz. …
File Format / SizePDF / 728 Kb
HMC7357LP5GE. GaAs pHEMT MMIC 2 WATT. POWER AMPLIFIER, 5.5 - 8.5 GHz. Evaluation PCB
HMC7357LP5GE GaAs pHEMT MMIC 2 WATT POWER AMPLIFIER, 5.5 - 8.5 GHz Evaluation PCB
HMC7357LP5GE
v01.0918
T M R - S E W O R & P A E IN S - L R IE LIF P M A
List of Materials for Evaluation PCB EV1HMC7357LP5 [1]
Item Description The circuit board used in the application should use J1 - J4 "K" Connector, SRI RF circuit design techniques. Signal lines should J7, J8 DC Pin have 50 Ohm impedance while the package ground C2, C3, C9, C12, C16, C19 100 pF Capacitor, 0402 Pkg. leads and exposed paddle should be connected C1, C4, C10, C11, C15, C20 10000 pF Capacitor, 0402 Pkg. directly to the ground plane similar to that shown. C21, C22, C25, C27, C28, C30 4.7 uF Capacitor, Case A Pkg. A sufficient number of via holes should be used to R1, R2 43.2 Ohm Resistor, 0402 Pkg connect the top and bottom ground planes. The U1 HMC7357LP5GE Amplifier evaluation circuit board shown is available from PCB [2] 600-00901-00 Eval Board Analog Devices, upon request. [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
9
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features General Description Functional Diagram Electrical Specifications Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature P1dB vs Supply Voltage Output IP3 vs. Supply Voltage, Pout/tone = +20 dBm Output IM3 @ Vdd = +6V Output IM3 @ Vdd =+7V Output IM3 @ Vdd = +8V Power Compression @ 6 GHz Power Compression @ 7 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Package Information Application Circuit List of Materials for Evaluation PCB EV1HMC7357LP5 [1] Evaluation PCB Pin Descriptions Gain & Power vs. Supply Current @ 7 GHz Gain & Power vs. Supply Voltage @ 7 GHz Power Compression @ 8 GHz Reverse Isolation vs. Temperature Output IP3 vs. Temperature, Pout/tone = +20 dBm Output IP3 vs. Supply Current, Pout/tone = +20 dBm P1dB vs. Supply Current Psat vs. Supply Current Psat vs. Temperature Psat vs. Supply Voltage
