Datasheet HMC1086F10 (Analog Devices) - 5
Description25 WATT Flange Mount GaN MMIC POWER AMPLIFIER, 2 - 6 GHz
Pages / Page12 / 5 — HMC1086F10. 25 WATT FlAnge MounT gAn MMIC. PoWeR AMPlIFIeR, 2 - 6 gHz. …
File Format / SizePDF / 728 Kb
HMC1086F10. 25 WATT FlAnge MounT gAn MMIC. PoWeR AMPlIFIeR, 2 - 6 gHz. output IM3 @ Vdd= +32V. Power Compression @ 2 gHz
HMC1086F10 25 WATT FlAnge MounT gAn MMIC PoWeR AMPlIFIeR, 2 - 6 gHz output IM3 @ Vdd= +32V Power Compression @ 2 gHz
HMC1086F10
v06.1017
50 50 3000 T 45 2790 ) (% 40 2580 m 40 E A 35 2370 s ) ), P 30 2160 Idd (dB (dBc 30 IN 25 1950 (mA) 3 A IM r - 20 1740 ), G m e 15 1530 20 10 1320 out(dB w P 5 1110 o 10 0 900 26 28 30 32 34 36 38 40 p 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 Pout/TONE (dBm) INPUT POWER (dBm) 2 GHz 5 GHz Pout Gain PAE 3 GHz 6 GHz 4 GHz r & Idd A e
Power Compression @ 4 gHz Power Compression @ 6 gHz
50 3300 50 3000 lin 45 3060 45 2790 ) (% 40 2820 (% 40 2580 E E A 35 2580 A 35 2370 s - ), P ), P 30 2340 Idd 30 2160 Idd r (dB (dB IN 25 2100 (mA) IN 25 1950 (mA) A A ie 20 1860 ), G 20 1740 ), G m m 15 1620 15 1530 10 1380 10 1320 lif out(dB out(dB P P 5 1140 5 1110 p 0 900 0 900 m 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 A INPUT POWER (dBm) INPUT POWER (dBm) Pout Gain PAE Pout Gain PAE Idd Idd
gain & Power vs. gain & Power vs. Supply Voltage @ 4 gHz Supply Current @ 4 gHz
50 50 ) m m 45 45 sat (dB sat (dB 40 ), P 40 ), P m m (dB 35 (dB 35 4dB 4dB 30 ), P 30 ), P 25 ain (dB 25 ain (dB G G 20 20 24 26 28 30 32 550 650 750 850 950 1050 1150 1250 1350 1450 1550 1650 Vdd (V) Idd (mA) GAIN(dB) Psat(dBm) GAIN(dB) Psat(dBm) P4dB(dBm) P4dB(dBm) For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
5
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Power Compression @ 10 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
