Datasheet HMC659LC5 (Analog Devices) - 6
DescriptionGaAs PHEMT MMIC POWER AMPLIFIER, DC - 15 GHz
Pages / Page8 / 6 — HMC659LC5. GaAs PHEMT MMIC. POWER AMPLIFIER, DC - 15 GHz. Pin Descriptions
File Format / SizePDF / 482 Kb
HMC659LC5 GaAs PHEMT MMIC POWER AMPLIFIER, DC - 15 GHz Pin Descriptions
HMC659LC5
v04.0614
Pin Number Function Description Interface Schematic 1, 2, 4, 7 - 12, 14, No connection. These pins may be connected to RF T N/C 16 - 20, 23 - 30 ground. Performance will not be affected. M Gate Control 2 for amplifier. +3V should be 3 Vgg2 applied to Vgg2 for nominal operation. S - S This pad is DC coupled R 5 RFIN and matched to 50 Ohms. IE LIF Low frequency termination. Attach bypass 13 ACG3 P capacitor per application circuit herein. M R A 15 Vgg1 Gate Control 1 for amplifier. E W O RF output for amplifier. Connect the DC 22 RFOUT & Vdd bias (Vdd) network to provide drain current (Idd). See application circuit herein. 31 ACG2 R & P Low frequency termination. Attach bypass capacitor A per application circuit herein. E 32 ACG1 LIN 6, 21 GND Ground paddle must be connected to RF/DC ground. Ground Paddle I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 p o lic ra a tiopp n S su@ p h po irtttit : Pe. hocnom e: 1-800-ANALOG-D
