Datasheet HMC659LC5 (Analog Devices) - 8
DescriptionGaAs PHEMT MMIC POWER AMPLIFIER, DC - 15 GHz
Pages / Page8 / 8 — HMC659LC5. GaAs PHEMT MMIC. POWER AMPLIFIER, DC - 15 GHz. Evaluation PCB. …
File Format / SizePDF / 482 Kb
HMC659LC5. GaAs PHEMT MMIC. POWER AMPLIFIER, DC - 15 GHz. Evaluation PCB. List of Materials for Evaluation PCB 117494 [1]
HMC659LC5 GaAs PHEMT MMIC POWER AMPLIFIER, DC - 15 GHz Evaluation PCB List of Materials for Evaluation PCB 117494 [1]
HMC659LC5
v04.0614
T M S - S R IE LIF P M R A E W O R & P A E LIN
The circuit board used in the final application Item Description should use RF circuit design techniques. Signal J1, J2 SMA-SRI-NS lines should have 50 Ohm impedance while the J3, J4 2 mm Molex Header package ground leads and package bottom should C1, C2 4.7 µF Capacitor be connected directly to the ground plane similar to C3 0.1 µF Capacitor, 0603 Pkg. that shown. A sufficient number of via holes should C4, C5 100 pF Capacitor, 0402 Pkg. be used to connect the top and bottom ground C6, C7 10k pF Capacitor, 0402 Pkg. planes. The evaluation board should be mounted C8, C9 0.47 µF Capacitor, 0402 Pkg to an appropriate heat sink. The evaluation circuit U1 HMC659LC5 board shown is available from Hittite upon request. PCB [2] 117492 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 p o lic ra a tiopp n S su@ p h po irtttit : Pe. hocnom e: 1-800-ANALOG-D
