Datasheet HMC590 (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC 1 WATT POWER AMPLIFIER, 6 - 10 GHz
Pages / Page8 / 4 — HMC590. GaAs PHEMT MMIC 1 WATT. POWER AMPLIFIER, 6 - 10 GHz. Gain & …
File Format / SizePDF / 407 Kb
HMC590. GaAs PHEMT MMIC 1 WATT. POWER AMPLIFIER, 6 - 10 GHz. Gain & Power vs. Supply Voltage @ 8 GHz
HMC590 GaAs PHEMT MMIC 1 WATT POWER AMPLIFIER, 6 - 10 GHz Gain & Power vs Supply Voltage @ 8 GHz
HMC590
v02.0109
GaAs PHEMT MMIC 1 WATT POWER AMPLIFIER, 6 - 10 GHz Gain & Power vs. Supply Voltage @ 8 GHz Gain & Power vs. Supply Current @ 8 GHz
34 34 32 32 30 30 28 28 3 Gain (dBm), Psat(dBm) Gain (dBm), Psat(dBm) P1dB P1dB 26 Psat 26 Psat 24 24 IP 22 22 H GAIN (dB), P1dB GAIN (dB), P1dB 20 20 6.5 7 7.5 520 620 720 820 Vdd SUPPLY VOLTAGE (Vdc) Idd SUPPLY CURRENT (mA) S - C R
Reverse Isolation
IE
vs. Temperature, 7V @ 820 mA Power Dissipation
IF 0 6 L P -10 5.5 M -20 5 -30 +25C +85C -55C 6GHz R A -40 4.5 7GHz 8GHz E -50 9GHZ ISOLATION (dB) 4 10GHz W -60 POWER DISSIPATION (W) 3.5 O -70 -80 3 6 6.5 7 7.5 8 8.5 9 9.5 10 -14 -10 -6 -2 2 6 10 14 FREQUENCY (GHz) INPUT POWER (dBm) R & P A E IN L Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
3 - 73
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
