Datasheet HMC487LP5E (Analog Devices)
DescriptionSURFACE MOUNT PHEMT 2 WATT POWER AMPLIFIER, 9 - 12 GHz
Pages / Page6 / 1 — HMC487LP5E. SURFACE MOUNT PHEMT 2 WATT POWER. AMPLIFIER, 9 - 12 GHz. …
File Format / SizePDF / 957 Kb
HMC487LP5E. SURFACE MOUNT PHEMT 2 WATT POWER. AMPLIFIER, 9 - 12 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC487LP5E Analog Devices
HMC487LP5E
v03.0819
SURFACE MOUNT PHEMT 2 WATT POWER AMPLIFIER, 9 - 12 GHz Typical Applications Features
The HMC487LP5E is ideal for use as a Saturated Power: +33 dBm @ 20% PAE T power amplifier for: Output IP3: +36 dBm M • Point-to-Point Radios Gain: 20 dB • Point-to-Multi-Point Radios +7V @ 1300 mA Supply R - S • Test Equipment and Sensors 50 Ohm Matched Input/Output E • Military End-Use 25 mm2 Leadless SMT Package W O
The HMC487LP5E is a high dynamic range GaAs R & P PHEMT MMIC 2 Watt Power Amplifiers housed A in leadless 5 x 5 mm surface mount packages. E Operating from 9 to 12 GHz, the amplifier provides 20 dB of gain, +33 dBm of saturated power and 20% IN PAE from a +7V supply voltage. Output IP3 is +36 dBm typical. The RF I/Os are DC blocked and matched to 50 Ohms for ease of use. The HMC487LP5E eliminates S - L R the need for wire bonding, al owing use of surface mount manufacturing techniques. IE LIF P M A
Electrical Specifications, T = +25° C, Vdd1, 2, 3, 4, 5 = +7V, Idd = 1300 mA* A
Parameter Min. Typ. Max. Min. Typ. Max. Units Frequency Range 9 - 11 11 - 12 GHz Gain 17 20 19 22 dB Gain Variation Over Temperature 0.05 0.07 0.05 0.07 dB/ °C Input Return Loss 7 15 dB Output Return Loss 7 15 dB Output Power for 1 dB Compression (P1dB) 29 32 28 31 dBm Saturated Output Power (Psat) 33 32 dBm Output Third Order Intercept (IP3) 36 35 dBm Noise Figure 9 8 dB Supply Current (Idd)(Vdd = +7V, Vgg = -0.3V Typ.) 1300 1300 mA * Adjust Vgg between -2 to 0V to achieve Idd = 1300 mA typical. I F nf o or r p mati roic n e fu , d rnis e h leiv d e b ry y , a Analn o d t g D o p evic leac s i e o s bel rid ev e e rs d t : A o b n e a a lco c g D urat e e a v n ic d rels i , I abl n e c . H , O owe n vee T r, n e o chn F o o lo r p g ri y W ce a , d y el, P ive.O ry . B , anox 9 d t 10 o pl 6 a , N c o e orrw de o r o s d, M : Anal A 0 o 2 g D 0 e 6 vi 2 c - e 9 s 10 , I 6 nc., responsibility is assumed by Analog Devices for it P s u h se on , no er f: 78 or an 1- y i 3 nfr2in9g-e4 m 7 e 0 nt 0 • O s of paterd nt e s or o r ot n h leir rights of third parties that may result from its use. Specifications subject to change without notice. No ne a O t w n w e Te w ch.a n n ol a o lgog. y Wcao y m , P.O. Box 9106, Norwood, MA 02062-9106
1
license is granted by implication or otherwise under an A y pa p te p n li t o ca r p t atio enn S t rig u ht pp s o o f A rnta: P lo h g D o e n vi e ce : 1 s. -80 P 0 ho -A ne NA : 7 L 81 O -3 G 2 - 9-D4700 • Order online at www.analog.com Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
