Datasheet HMC459 (Analog Devices) - 5
DescriptionGaAs PHEMT MMIC POWER AMPLIFIER, DC - 18 GHz
Pages / Page8 / 5 — HMC459. GaAs PHEMT MMIC. POWER AMPLIFIER, DC - 18 GHz. Pad Descriptions. …
File Format / SizePDF / 401 Kb
HMC459. GaAs PHEMT MMIC. POWER AMPLIFIER, DC - 18 GHz. Pad Descriptions. 3 - 32
HMC459 GaAs PHEMT MMIC POWER AMPLIFIER, DC - 18 GHz Pad Descriptions 3 - 32
HMC459
v01.1007
Pad Number Function Description Interface Schematic 3 1 RFIN This pad is DC coupled and matched to 50 Ohms. IP Gate Control 2 for amplifi er. +3V should be applied to Vgg2 H 2 Vgg2 for nominal operation. Vgg2 may be adjusted between 0 to +5V to temperature compensate gain. S - C RF output for amplifi er. Connect the DC R 4 RFOUT & Vdd bias (Vdd) network to provide drain current (Idd). See application circuit herein. IE IF L Gate Control 1 for amplifi er. Adjust between -2 to 0V P 5 Vgg1 to achieve Idd= 290 mA. M R A Low frequency termination. Attach bypass capacitor per E 3 ACG1 application circuit here in. W O Low frequency termination. Attach bypass capacitor per 6 ACG2 application circuit here in. R & P A E Die GND Die bottom must be connected to RF/DC ground. Bottom IN L Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
3 - 32
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
