Datasheet HMC453ST89, 453ST89E (Analog Devices) - 9
DescriptionInGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 9 — HMC453ST89 / 453ST89E. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC453ST89 / 453ST89E. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Noise Figure. Output IP3 vs. Temperature @ 1900 MHz
HMC453ST89 / 453ST89E InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs Temperature @ 1900 MHz
v02.0710
InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs. Temperature @ 1900 MHz vs. Temperature @ 1900 MHz
52 10 50 9 48 8 46 7 44 6 42 GURE (dB) 5 40 9 OIP3 (dBm) 4 38 +25 C SE FI +85 C +25 C 3 36 -40 C +85 C NOI -40 C 34 2 32 1 T 30 0 1.7 1.8 1.9 2 2.1 1.7 1.8 1.9 2 2.1 FREQUENCY (GHz) FREQUENCY (GHz) R - SM
Reverse Isolation Gain, Power & IP3
E
vs. Temperature @ 1900 MHz vs. Supply Voltage @ 1900 MHz
W 0 55 O 50 45 -5 40 35 +25 C R & P -10 +85 C 30 Psat (dBm), OIP3 (dBm) A -40 C 25 Gain E ISOLATION (dB) 20 P1dB Psat -15 OIP3 15 IN 10 -20 5 1.7 1.8 1.9 2 2.1 4.5 4.75 5 5.25 5.5 S - L GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) R IE
ACPR vs. Supply Voltage @ 1960 MHz
IF
Power Compression @ 1900 MHz CDMA 2000, 9 Channels Forward
L 40 -30 P -35 35 M Pout Gain -40 CDMA2000 PAE A 30 Frequency: 1.96 GHz 4.5V -45 Integration BW: 1.228 MHz 25 5V -50 Forward Link, SR1, 9 Channels 5.5V 20 -55 -60 15 ACPR (dBc) -65 10 -70 Pout (dBm), Gain (dB), PAE (%) 5 -75 0 -80 10 12 14 16 18 20 22 24 26 28 14 16 18 20 22 24 26 28 INPUT POWER (dBm) OUTPUT CHANNEL POWER (dBm) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
9 - 176
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
