Datasheet HMC453QS16G, 453QS16GE (Analog Devices) - 3
DescriptionInGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 3 — HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Noise Figure. Output IP3 vs. Temperature @ 400 MHz
HMC453QS16G / 453QS16GE InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs Temperature @ 400 MHz
v01.0205
InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs. Temperature @ 400 MHz vs. Temperature @ 400 MHz
52 10 50 9 48 8 46 7 44 6 42 GURE (dB) 5 40 +25 C 11 +25 C 4 OIP3 (dBm) +85 C SE FI 38 +85 C 3 -40 C 36 -40 C NOI 2 34 32 1 T 30 0 0.35 0.37 0.39 0.41 0.43 0.45 0.35 0.37 0.39 0.41 0.43 0.45 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Reverse Isolation Gain, Power & IP3
R
vs. Temperature @ 400 MHz vs. Supply Voltage @ 400 MHz
IE 0 55 IF 50 -5 L 45 P Gain -10 +25 C P1dB 40 Psat +85 C M OIP3 -15 -40 C 35 Psat (dBm), OIP3 (dBm) 30 -20 R A ISOLATION (dB) 25 -25 E 20 -30 W 15 O -35 10 0.35 0.37 0.39 0.41 0.43 0.45 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) & P R
ACPR vs. Supply Voltage @ 400 MHz
A
Power Compression @ 400 MHz W-CDMA, 64 DPCH
E 50 -10 IN -15 45 Pout L -20 40 Gain W-CDMA -25 PAE Frequency: 400 MHz 35 -30 Integration BW: 3.84 MHz 64 DPCH 30 -35 25 -40 4.5V 5V -45 5.5V 20 ACPR (dBc) -50 15 -55 10 -60 Pout (dBm), Gain (dB), PAE (%) 5 -65 Source ACPR 0 -70 -10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 8 10 12 14 16 18 20 22 24 26 28 INPUT POWER (dBm) Channel Power (dBm) Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 180
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
