Datasheet HMC452QS16G, 452QS16GE (Analog Devices) - 3
DescriptionInGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Pages / Page22 / 3 — HMC452QS16G / 452QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC452QS16G / 452QS16GE. InGaP HBT 1 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Output IP3 vs. Temperature @ 400 MHz
HMC452QS16G / 452QS16GE InGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Output IP3 vs Temperature @ 400 MHz
v01.0205
InGaP HBT 1 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Output IP3 vs. Temperature @ 400 MHz Noise Figure vs. Temperature @ 400 MHz
50 10 48 9 46 8 44 7 42 6 40 GURE (dB) 5 11 +25 C 38 OIP3 (dBm) 4 +85 C +25 C SE FI 36 -40 C +85 C 3 NOI -40 C 34 2 T 32 1 30 0 0.35 0.37 0.39 0.41 0.43 0.45 0.35 0.37 0.39 0.41 0.43 0.45 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Reverse Isolation Gain, Power & IP3 vs. Temperature @ 400 MHz vs. Supply Voltage @ 400 MHz
0 50 -5 45 PLIFIER 40 -10 +25 C M +85 C 35 -15 -40 C 30 Psat (dBm), OIP3 (dBm) -20 25 ISOLATION (dB) ER A -25 20 W -30 15 Gain Psat P1dB OIP3 O -35 10 0.35 0.37 0.39 0.41 0.43 0.45 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) & P R
ACPR vs. Supply Voltage @ 400 MHz
A
Power Compression @ 400 MHz W-CDMA , 64 DPCH
E 55 -10 50 -15 LIN Pout -20 45 Gain W-CDMA PAE -25 40 Frequency: 400 MHz -30 Integration BW: 3.84 MHz 35 64 DPCH -35 4.5V 30 -40 5V 25 5.5V -45 ACPR (dBc) 20 -50 15 -55 10 -60 Pout (dBm), Gain (dB), PAE (%) 5 -65 Source ACPR 0 -70 -10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 8 10 12 14 16 18 20 22 24 26 28 INPUT POWER (dBm) Channel Power (dBm) Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 136
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
