Datasheet HMC409LP4E (Analog Devices) - 3
DescriptionGaAs InGaP HBT 1 WATT POWER AMPLIFIER, 3.3 - 3.8 GHz
Pages / Page8 / 3 — HMC409LP4E. GaAs InGaP HBT 1 WATT. POWER AMPLIFIER, 3.3 - 3.8 GHz. P1dB …
HMC409LP4E. GaAs InGaP HBT 1 WATT. POWER AMPLIFIER, 3.3 - 3.8 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC409LP4E GaAs InGaP HBT 1 WATT POWER AMPLIFIER, 3.3 - 3.8 GHz P1dB vs Temperature Psat vs Temperature
HMC409LP4E
v04.1217
GaAs InGaP HBT 1 WATT POWER AMPLIFIER, 3.3 - 3.8 GHz P1dB vs. Temperature Psat vs. Temperature
36 36 T 34 34 m 32 s 32 ) m 30 Bm 30 (dB (d r - 1dB 28 28 P +25 C e PSAT +85 C 26 +25 C 26 -40 C w +85 C 24 -40 C 24 o p 22 22 3 3.2 3.4 3.6 3.8 4 3 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 3.9 4 FREQUENCY (GHz) FREQUENCY (GHz) r & A e
Output IP3 vs. Temperature Power Compression @ 3.5 GHz
50 40 lin ) 35 % ( 46 E A 30 s - ), P ) B 25 r 42 d m ( IN (dB 20 A ie 3 +25 C IP 38 +85 C ), G 15 -40 C m B d lif t ( 10 Pout (dBm) 34 u o p Gain (dB) P 5 PAE (%) m 30 0 A 3 3.2 3.4 3.6 3.8 4 -20 -16 -12 -8 -4 0 4 8 FREQUENCY (GHz) INPUT POWER (dBm)
Gain & Power vs. Supply Voltage Noise Figure vs. Temperature
35 12 ) m B 34 +25 C d 10 +85 C t ( a ) -40 C s 33 B d ( 8 ), P E m R B 32 U d ( IG 6 B d F 31 1 E IS ), P O 4 B 30 d N Gain ( Psat IN 2 A 29 P1dB G 28 0 4.75 5 5.25 3 3.2 3.4 3.6 3.8 4 Vcc SUPPLY VOLTAGE (Vdc) FREQUENCY (GHz) For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications EVM vs. Temperature @ 3.5 GHz OFDM 54 Mbps Signal Power Dissipation Gain, Power & Quiescent Supply Current vs. Vpd @ 3.5 GHz Noise Figure vs. Temperature Gain & Power vs. Supply Voltage Power Compression @ 3.5 GHz Output IP3 vs. Temperature Psat vs. Temperature P1dB vs. Temperature Power Down Isolation vs. Temperature Reverse Isolation vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Absolute Maximum Ratings Typical Supply, Current vs. Supply Voltage, Vcc1 = Vcc2 = Vpd Outline Drawing Package Information Application Circuit Pin Descriptions Evaluation PCB List of Materials
